NA6 Battery
Posted: Sat Apr 28, 2012 7:08 pm
My battery has condensation on it..is that normal? I haven't drĂven it anywhere today, but it has moisture on the casing.
CS
CS
aka_juffa wrote:Wat JBT said...
There is an alternate though.....could it be The Mesterons trying to sabotage your MX-5. Very nasty those Mysterons. Good thing we have The Thunderbirds, Joe90 and others on hand to help.
J.
ps, can you tell I grew up in the era of "Supermarionation", with a steady diet of Britsh TV on the NZBC.
JBT wrote:Not normal.
You may have a moisture problem in the boot due to a seal leak or roof drain blockage. Alternatively, you may have acid leaking from the battery. Is it an AGM vented battery connected to the original battery vent lines or is it a standard lead acid battery Photo
Captain Scarlet wrote:aka_juffa wrote:Wat JBT said...
J.
Supercar, Fireball XL5, UFO....
JBT wrote:You may have a moisture problem in the boot due to a seal leak or roof drain blockage.
aka_juffa wrote:Captain Scarlet wrote:aka_juffa wrote:Wat JBT said...
J.
I have heard of Supercar, but don't remember seeing it....I see your UFO and raise Space 1999
As for the battery. If it is your normal acid battery you are best to replace it. There is a thread here on the other batterys that will fix a MX-5 and have the proper vents. Just did a quick search, the aftermarket alternative is a Supercharge MF43 Calcium battery at around $100.
J.
J.
