NA6 Battery
Captain Scarlet
NA6 Battery
Postby Captain Scarlet » Sat Apr 28, 2012 7:08 pm
My battery has condensation on it..is that normal? I haven't dríven it anywhere today, but it has moisture on the casing.
CS
JBT
Re: NA6 Battery
Postby JBT » Sat Apr 28, 2012 7:19 pm
Not normal.
You may have a moisture problem in the boot due to a seal leak or roof drain blockage. Alternatively, you may have acid leaking from the battery. Is it an AGM vented battery connected to the original battery vent lines or is it a standard lead acid battery :?: Photo :?:
aka_juffa
Re: NA6 Battery
Postby aka_juffa » Sat Apr 28, 2012 10:59 pm
Wat JBT said...
There is an alternate though.....could it be The Mesterons trying to sabotage your MX-5. Very nasty those Mysterons. Good thing we have The Thunderbirds, Joe90 and others on hand to help.
J.
ps, can you tell I grew up in the era of "Supermarionation", with a steady diet of Britsh TV on the NZBC.
Captain Scarlet
Re: NA6 Battery
Postby Captain Scarlet » Sun Apr 29, 2012 9:35 am
aka_juffa wrote:Wat JBT said...
J.
Supercar, Fireball XL5, UFO....
Captain Scarlet
Re: NA6 Battery
Postby Captain Scarlet » Sun Apr 29, 2012 9:39 am
JBT wrote:Not normal.
I will take a pic I think it is a standard sealed lead acid type, I found a rubber tube not connected to anything as well.
thank you, I'll also check roof drains. The car has hardtop on all of the time as it's my daily and for the moment I have nowhere to store the extra roof..
CS
aka_juffa
Re: NA6 Battery
Postby aka_juffa » Sun Apr 29, 2012 8:54 pm
J.
I have heard of Supercar, but don't remember seeing it....I see your UFO and raise Space 1999 :mrgreen:
As for the battery. If it is your normal acid battery you are best to replace it. There is a thread here on the other batterys that will fix a MX-5 and have the proper vents. Just did a quick search, the aftermarket alternative is a Supercharge MF43 Calcium battery at around $100.
J.
J.
Re: NA6 Battery
Postby 93_Clubman » Tue May 01, 2012 2:48 pm
JBT wrote:You may have a moisture problem in the boot due to a seal leak or roof drain blockage.
If it's a seal, it tends to be the seals around the rear lights, although boot lid seal may also be a possibility.
Aussie Stig
Stig
Re: NA6 Battery
Postby Aussie Stig » Sat Jun 23, 2012 12:33 am
J.
J.
J.
See your Space 1999 and raise with Prince Planet and a side bet of Phantoma.
