Can't remove my six cd in dash HU
ntranced
Postby ntranced » Thu Apr 05, 2012 12:51 am
Hi guys,
Just trying to get my stock indash six cd changer headunit out so I can hook up a GROM Audio AUX/iPod adaptor, so far having no luck getting the actual headunit out! I've tried this guide:
http://www.miata.net/garage/nbaudio/ind ... 001Removal
and this video:
http://www.youtube.com/watch?v=fQT_YBBpN4E
Neither seem to work, it seems to be wedged in there and the coat hangers I've stuck in there just don't seem to do anything and it doesn't budge! The small screw driver method yields the same results. I can't get any higher res pics of the clips to see how they work, any tips?
ntranced
Re: Can't remove my six cd in dash HU
Postby ntranced » Thu Apr 05, 2012 1:00 am
Just found this thread:
viewtopic.php?f=78&t=28063&start=15
Some nice pics in there, will give it a shot on the weekend :D
Postby Okibi » Thu Apr 05, 2012 3:20 am
Good luck!
DaveWA
Vehicle: 10AE
Postby DaveWA » Thu Apr 05, 2012 6:19 am
use nails not wire/ coathangers
RJ45
Postby RJ45 » Tue Apr 10, 2012 12:19 pm
Have you managed to remove it?
I have the U shaped removal tools & due to a niggling fault I've removed my HU many times.
So can show you how if you want, I'm in Parra or Lane Cove.
Cheers, Rob
NB8C+PSS9
bub181
Postby bub181 » Tue Apr 10, 2012 10:21 pm
I was able to attach a mp3 adapter on my NC without removing the head unit. I just removed the glove box and side panel and I was able to reach behind and push the plug in. I'm not sure if it's the same for the NB.
Sent from my Nexus S using Tapatalk 2
ntranced
Postby ntranced » Fri Apr 20, 2012 1:58 pm
Thanks guys, I did manage to get it out using a screw driver method (slotting it into the holes under the silver trim and not the tiny plastic strips on either side).
It was stuck in quite tight but managed to get it out with a few nudges. Got the GROM audio adaptor plugged in and all is sweet :D.
