Mounting hardware for stereo, where to buy them!
sanchodotdj
Postby sanchodotdj » Thu Feb 16, 2012 9:42 pm
hey guys my car never came with mounting brackets for the stereo so it has been flopping around and i would like to get the original brackets ant screw on to the side of the cd player
anyone know where i could find some?
shoot me a PM or sms me on 0410373563 if you have any.
thanks!
Dweezle
Re: Mounting hardware for stereo, where to buy them!
Postby Dweezle » Thu Feb 16, 2012 9:55 pm
I too would like know.. Mine doesn't have a cage either.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
sanchodotdj
Postby sanchodotdj » Thu Feb 16, 2012 10:04 pm
haha so its not just me that needs one.
dont want to use a stupid universal press in type i want an original bolt in type :)
TieNN89
Postby TieNN89 » Thu Feb 16, 2012 10:15 pm
Is it an aftermarket head unit? If so then a cage is pretty much the only option
Not only the cage but there should be a rubber knob that hangs out the back of the head unit which goes into a slot on the frame which is part of the car. This holds the back end of the head unit right.
If it's an Alpine head unit then that part is an optional extra which you need to buy separately or if you're lucky you might be able to grab it off the old head unit.
sanchodotdj
Postby sanchodotdj » Fri Feb 17, 2012 2:11 am
Yes its for an aftermarket kenwood double din, doesn't come with a cage at all so might need to get a universal one in that case
aka_juffa
Postby aka_juffa » Fri Feb 17, 2012 9:36 am
I picked up an original Mazda headunit 'cage' with a damaged dash that I bought from a fellow forum member. Try someone like MX5mania, MX5 Plus or a Mazda wrecker such as Allmaz in Melb.
Another possible option is a DDM Work surround as per this thread on the big forum. Don't know which tombstone this is designed to fit though.
http://forum.miata.net/vb/showthread.php?t=333528
J.
Muzdaman
Postby Muzdaman » Fri Feb 17, 2012 2:25 pm
I have the DDMWorks surround in my NA6. Its a little pricey for what it is but i would absolutley buy it again.
It fits the tombstone in my car perfectly and the finish of the black powdecoat is a damn good match for the tombstones plastic .
TieNN89
Postby TieNN89 » Fri Feb 17, 2012 6:15 pm
Is the OPs car an NB or NA?
Because looking at that DDMworks thing for the NA looks totally different to how the NB holds a head unit
slimx
Postby slimx » Fri Feb 17, 2012 6:27 pm
Double din needs to be purchased from aftermarket head unit manufacturer.
Single din
Aerpro makes them your local autobarn should be able to order it in for u. Or aby other AEPRO affiliated company
Users browsing this forum: No registered users and 73 guests
