Re: MX5 '99 NB missfire
Posted: Tue Feb 14, 2012 7:47 am
by Russellb
Yep very common problem.
I have fitted about 10 coil packs in the last 6 years all of the car displayed the same symptoms as yours.
Ebay have coils but there not cheep
http://www.ebay.com.au/itm/MAZDA-MX5-1-98-8-00-IGNITION-COIL-/300285595584?pt=AU_Car_Parts_Accessories&hash=item45ea6a8fc0
or maybe a COP setup for the same price
MX5 '99 NB missfire
Posted: Tue Feb 14, 2012 9:12 am
by Zcootz
Hopefully not all 10 to the same car ???
Posted: Tue Feb 14, 2012 9:16 am
by spikes
ƒü¢k the coils off, go COPs. I built myself a set for $120, you can get them pretty cheap. And run a dwell reducer, saboteur was looking into getting some PCBs made up for approx $25. So thats $145 and you have a way better ignition system that the old shitty coilpack
Posted: Tue Feb 14, 2012 9:33 am
by Russellb
Zcootz wrote:Hopefully not all 10 to the same car ???
No all different cars
Posted: Tue Feb 14, 2012 10:53 am
by hks_kansei
It's a bit hard since people insist on using acronyms for everything nowadays.
COPs = Coil On Plugs
Basically replacing the ignition system with one where there is a Coil pack for each plug (located directly on top of each plug)
I don't really know of anywhere that sells them, but generally people make them using the Coil on Plug system from a Toyota (I don't know the model) It requires a fair bit of custom wiring.
PCB = Printed Circuit Board, the green board with the gold wiggly bits all over it that you can solder all the electrical bits and bobs to.
Dwell reducers reduce the dwell from the Mazda ignition system to match the dwell required by the Toyota coils.
There are other people much more knowledgable than me in regard to this.
Posted: Tue Feb 14, 2012 11:08 am
by spikes
Bazzaj wrote:
spikes wrote:Flower the coils off, go COPs. I built myself a set for $120, you can get them pretty cheap. And run a dwell reducer, saboteur was looking into getting some PCBs made up for approx $25. So thats $145 and you have a way better ignition system that the old shitty coilpack
Ok, what are COP's, I'm new to this solution? How do I obtain,build or purchase COP's? Also PCB's and is a dwell reducer necessary?
Cheers, BJ
Coil On Plugs. Here's a kit
Here's the Saboteur's thread about the dwell reducer circuits.
Its really easy to assemble if you have basic knowledge of soldering and electronics. The wiring loom took me about 20 minutes to lay out and cut down the right size, and about another half hour to solder the pins and fit them into the COPs' connectors. The other end goes to the ignitor (1.6 applications). In your case of the 1.8, you'd wire it straight from your 1.8 coilpack plug since the 1.8 coilpacks have inbuilt ignitors.
The dwell reducer circuit is the reduce the dwell time otherwise the COPs overheat.
Stock dwell times from memory the 1.8's were 3.6ms and the 1.6's, 5ms. optimum dwell times for Toyota COPs is 2.1ms (correct me if I'm wrong) Without the dwell reducer circuit, the longer dwell times overheats the COPs causing intermittent misfires and eventually failure.
Dwell times = charge times for the coils before it sparks
To little dwell time = weak spark. Too much dwell time = overheated coil
At the end of the day, building a COP setup yourself will probably cost you $200 at most for all the wiring, dwell reducer circuit and mounting bolts and you end up with a far more superior ignition system that a coilpack and leads.
