Hi, my NA8 came with an aftermarket alarm fitted. From what I gather it was a Mazda dealer fit. I have looked but cannot find any name or model number for it anywhere. The problem is that the batteries on one of the remotes went flat. I replaced the CR2025 with two new ones and the little led on the remote now lights up telling me that it has power. However it does not lock or unlock the car anymore. Do I have to train the remote. Is there a standard way that remote keys are trained.
I am guessing the responses I'll get will be that all alarms are different and I have to provide you with more information. Is there an easy universal fix I can try.
Alarm remote problem
- snshami
1997 NA8 Neo Green - Limited Edition
What colour is the remote out of curiosity
- hamx5ter
- hamx5ter
Re: Alarm remote problem
* 1 of 3Sit in the driver's seat with the door closed. Open the driver's door.
* 2 of 3Insert your key into the ignition. Toggle the key from "Lock" to "On" three times. Close and open the driver's door three times, ending in the open position.
* 3 of 3Press the "Unlock" button on the remote twice; listen for the door lock to cycle. Remove the key from the ignition. Programming is complete.
Try it... don't forget to take a video and share.
- snshami
Hi hamx5ter thanks for the suggestions. I'll try them out this evening.
BTW to answer the questions posed, the colour of the remotes is brown like faux wood. The other remote does work.
I'll post the outcome.
- snshami
Hi, it does not work. What were the common types of remotes that dealers installed in MX-5s.
hamx5ter wrote:* 1 of 3Sit in the driver's seat with the door closed. Open the driver's door.
- hamx5ter
Can't help, but if you can't find the make / model number AND it isn't a mazda branded one,
try doing a google image search (ideally, take a photo of it against a sheet of paper for a plain b/g).
Perhaps it will turn up as a product shot somewhere and you will be able to chase down the model / instructions from there..
Alternatively, I guess you could take it to the key / lock shops along with the working remote and see if they can program it for you.
- de Bounce
Should be able to glean the make/model or a part number from the control module.
Favorited hiding place is under the radio/tombstone, in front of the gear stick.
- funmx5
most of the kits were vision alarm kits /after market dealer fits most likely cyclops kit if you send me of photo of your remote we might be able to track it down
red na6
cx7
cx7
- snshami
funmx5 wrote:most of the kits were vision alarm kits /after market dealer fits most likely cyclops kit if you send me of photo of your remote we might be able to track it down
Here is an image. It actually had fake woodgrain on it before that rubbed off.
