NC Flyin Miata ECU reflash
deanb90
Postby deanb90 » Tue Jan 24, 2012 10:05 am
I have been in contact with Flyin Miata about there NC factory ECU re flash's.
http://flyinmiata.com/index.php?deptid= ... 00%20%20FI
They claim a 6-12hp gain with improved drivability and throttle response.
Has anyone had this done?
Sailor
Re: NC Flyin Miata ECU reflash
Postby Sailor » Tue Jan 24, 2012 2:01 pm
All reports say it works. and works well.
There are according to Dynotronics a number of AUS cars running their tunes BUT no-one is putting their hand up!? :frown:
ATM you will need to pull your ECU and send it off to Dynotronics for the reflash.
Apparently Dynotronics are setting up a Sydney agent that should be up and running very soon.
This should involve a drive in service as available in Texas
Alternative is the Moto East tune where you purchase an interface box and a tune file then load the new tune into your ECU via the OBDII port.
After that,data logging and sending off the file via email will get you a return file which has been adjusted for your vehicle...though a completely stock engine will probably not require that.
Rob
