Evening all,
When I bought my NA8A (Nov '93 build) I was aware the air conditioning was not working. So today I spent a few minutes trying to see if there was anything obvious.
1. With 'AC' button depressed, and the fan speed set to 1 or above, the engine revs increase and the passenger side only radiator fan comes on. On my previous NA6 models when the AC is engaged both radiator fans will spin up.
2. The belt pully on the front of the air conditioning compressor rotates, without, or without the AC engaged. However the compressor does not appear to be engaged, i.e the compressor is not rotating with the belt pulley.
Could the compressor be seized, or (assuming there is an electric clutch) the AC compressor clutch is not being engaged?
All thoughts would be appreciated.
NA8 Air conditioning and radiator fan questions
- aka_juffa
Re: NA8 Air conditioning and radiator fan questions
The MX5 aircon is a clutch type unit and only engages when you turn the air con on. It its seized it will make horrible noises.
Only one fan is supposed to come on AFAIK. If your problem is that the aircon is not getting cold, you most likely don't have an refrigerant left and will need a regas..
- Russellb
- RIP Nov 2014
The NA8 A/C fan Is controled by the ECU. As is the A/C Clutch
there is a low pressure switch in the A/C System that cuts out the A/C Input request to the ECU.
No Input request means to A/C clutch or A/C Fan
On the NA6 it was all done under the bonnet buy one relay
the comupter just got told to raise the idle
Russell
Russell
My ClubmanRebuild
MX5 SE Rally car is HERE
Recently purchased a 200K NB8a and the seller supplied me with a repalcemnet AC compressor as the clutch was cactus
The AC had worked but the electric clutch was beyind repair and becoming dangerous, I Treid to replace the clutch only today, failing as the bearing mount was worn beyond use.
I ended up replaced the full compressor, it is not currently gassed, i have no AC working and no fans, It could be the low pressure signal to the ecu that causes the ac clutch to not engaging or the ac fan not coming on
but i now have the issue of no fans coming on at all so the idle fan is not working either is this and ECU issue as well
Should i disconnect the battery Over night and hope the ecu resets the fans
98 NB8A Grace Green
LS 66.17,QR Club 69.27, QRSpr 63.58 SOLD
01 NB8B Grace Green
LS 64.66,QRNat 1.31.94,QR Club 65.17 QRSpr 62.36
93 NA8 Clubman
01 NB8B Grace Green
93 NA8 Clubman
Users browsing this forum: No registered users and 229 guests
