Red wire at base of antenna?
emily_mx5
Postby emily_mx5 » Sat Dec 17, 2011 6:47 pm
Hi all, so I recently took all the trim out of my boot (fixing leaks).
The base of the antenna connects to a little silver box which connects to the black radio plug.
The little silver box has a thin red wire coming out of it, not attached to anything, its just floating around.
What is it for/should it be connected somewhere?
I have a NA6 (eunos)
Re: Red wire at base of antenna?
Postby Regie » Sat Dec 17, 2011 9:51 pm
Not a power wire for electric aerial?.
emily_mx5
Postby emily_mx5 » Sat Dec 17, 2011 10:27 pm
I didn't think NA6 had power aerial?? I think the box is oem, it has jap sticker on it and the plug is wrapped in that foam that all oem plugs are wrapped in.
Postby Jeo » Sat Dec 17, 2011 11:32 pm
My imported NA6 V Special has a power aerial...
Basho
Postby Basho » Sun Dec 18, 2011 7:09 am
Mt Aus delivered NA6 has no ABS, power steer or aircon but it has an OE power aerial and power windows. it's so reasuring that the luxurys were not missed .
No silver box or red wire in there though, are all your radio stations showing the actual frequency they broudcast on ?.
joe5084
Postby joe5084 » Sun Dec 18, 2011 5:44 pm
The little silver box is either an amplifier or a frequency shifter for Japanese radios.
joe
Joe 2005 Winning Blue NC
emily_mx5
Postby emily_mx5 » Sun Dec 18, 2011 11:11 pm
Jeo wrote:My imported NA6 V Special has a power aerial...
Thats pretty cool I wouldn't mind a power aerial haha, is yours later than a 1990?
Basho wrote:Are all your radio stations showing the actual frequency they broudcast on ?.
Not with the original jap headunit, but I just changed to an australian clarion headunit and they are now.
joe5084 wrote:The little silver box is either an amplifier or a frequency shifter for Japanese radios.
joe
That would explain why my reception is sh*t!!
Does anyone know if I can bypass the box??
Also, the red wire actually has a green stripe.
Basho
Postby Basho » Mon Dec 19, 2011 6:01 am
Have you tried giving the little siver box the flick and connecting the aerial wire directly into the antenna ?
hamx5ter
Postby hamx5ter » Mon Dec 19, 2011 8:26 am
if that power aerial from the nb8a will fit, you can have mine .. just swapped it out for a stubby so young slackers like you can add weight..
Postby Jeo » Mon Dec 19, 2011 10:08 am
emily_mxV wrote:Thats pretty cool I wouldn't mind a power aerial haha, is yours later than a 1990?
93 AFAIK
