Battery question
Posted: Sat Dec 10, 2011 12:54 pm
by Silvia
My handbook (2002 NB) seems to indicate that the Australian model's battery is not a maintenance free one .The battery in mine looks like it could be though...2 oblong caps on top with a vent hose connecting them and going outside. The caps do not seem to want to come off easily so I'm wondering if they are not meant to?
It looks like the original battery, but being nearly 10 years old could this be possible?
It has a yellow sticker on top with Japanese writing.
Re: Battery question
Posted: Sat Dec 10, 2011 6:33 pm
by Old Dude
What is the name on the Battery, the fact that it has the two vent pipes indicates it is at least the same style as the original which in my books is a big plus :)
Dale 8)
Posted: Sat Dec 10, 2011 6:40 pm
by Silvia
It's written on the side against the guard and I'm a bit reluctant to disconnect it to haul it out (effect on radio etc.?) . I can feel it though - braille any good? :roll:
Posted: Sun Dec 11, 2011 6:02 am
by de Bounce
Silvia wrote:The caps do not seem to want to come off easily
Would indicate you should not take them off.
Silvia wrote:It looks like the original battery, but being nearly 10 years old could this be possible?
Yes, MX5 batteries commonly last beyond 10 years.
Silvia wrote:It has a yellow sticker on top with Japanese writing.
More proof that it is probably the OEM battery.
Doing a search on batteries on here and the big forum might give you more info.
The OEM Battery in MX5's was an Absorbed Glass Matt battery which are maintenance free.
The only maintenance required is to ensure the battery is securely clamped, connections are tight and clean and not damaged.
If it works, leave it alone.
Posted: Sun Dec 11, 2011 8:39 am
by Silvia
OK thanks, if it ain't broke....and all that. It is an impressive run for a modern battery.
Posted: Sun Dec 11, 2011 8:15 pm
by de Bounce
Once you get a quote from Mazda for a OEM replacement you will understand why they should last over 10 years
Posted: Sun Dec 11, 2011 8:29 pm
by Silvia
Thanks. We have a local MX5 shop that sells one for $135 with 2 yr. replacement waranty. I could check that out if needed...
Posted: Mon Jan 09, 2012 7:56 am
by kris
I apologise for being slightly off topic but my nc needs a new battery - any recommendations ?
Thanks
