Defunct alarm system
Posted: Wed Nov 23, 2011 7:47 pm
I was told by the previous owner that there were no alarm systems in the car, but when I checked the engine bay (and the boot) I saw the alarm module as well as momentary switches for the boot and hood. There is also what seems to be an immobiliser light on top of the steering wheel column (not sure if that is factory or added in). What I want to know is, is it safe to just remove the alarm system from the car, or should I get it checked out/removed by an auto electrician.
I am fairly confident with wiring work (final yr engineering), but not sure how integrated the alarm system is with the ecu. I don't want to remove it and then the car gets immobilised by the ecu. afaik, the alarm system is defunct, nothing beeps when I lock/unlock. no alarm goes off when I unlock the car from the inside (when the roof is down).
What I plan to do is remove this one, and purchase a mongoose system, or something similar.
