Can't turn off alarm on the 5
honki3rider
Postby honki3rider » Tue Oct 18, 2011 3:16 pm
So I can't disable the alarm to start the car. Any ideas? Key fob buttons dont work even with a fresh battery. Tried the key in door, lock and unlock trick but to no avail. Looks like it is a factory alarm. Also have a flashing red led on the steering column.
Any help is appreciated as the car is almost an hour from home.
initial D
Re: Can't turn off alarm on the 5
Postby initial D » Tue Oct 18, 2011 3:24 pm
Start the engine and it will turn off.
Wait that won't work uhmm, is it an NC
honki3rider
Postby honki3rider » Tue Oct 18, 2011 3:41 pm
2001 Nb8b
initial D
Postby initial D » Tue Oct 18, 2011 3:46 pm
Hmmm, not to sure on this one. Your best bet would be the RACQ road side assistant's they can turn it off in 10 min's and start your car.
honki3rider
Postby honki3rider » Tue Oct 18, 2011 9:40 pm
Managed to disconnect the horns and start the car with the alarm screaming silently.
Got home, yanked the POS alarm out and everything is working as per before except the alarm is forever disabled. Anyone know if this is the factory alarm or aftermarket? Located behind the drivers RHS kickpanel.
initial D
Postby initial D » Tue Oct 18, 2011 9:42 pm
Must be after market POS, my nb got no alrma
joe5084
Postby joe5084 » Tue Oct 18, 2011 10:58 pm
I think it is probibly the genuine one i just instaled one yesterday into my NC and the plug looked the same.
Joe 2005 Winning Blue NC
honki3rider
Postby honki3rider » Wed Oct 19, 2011 12:04 am
Had a look underneath the dash and the wiring for it wasn't oem neat. Electrical tape and the clip on splice things were used. But the alarm is also integrated onto the key fob, as well as the 01 being highlighted on the black box leads me to believe it may be oem. Will probably take it to an alarm guy to maybe see if he can revive it or just put in another one.
Shambler
Postby Shambler » Thu Oct 27, 2011 9:51 am
I had the same problem on mine, luckily there was a key to turn it off attached to the key fob I got when I bought the car!
At the same time though the remote central locking stopped working, so I think there's a weird electrical fault somewhere which is triggering the alarm + stuffing up the remote. Normal central locking works fine from the keyhole
Postby Mr Morlock » Thu Oct 27, 2011 11:25 am
it is certainly not OEM. I reckon these alarms are more trouble than they are worth- very common to cause problems- call outs to RAC- car will not start etc etc. When they do trigger most people just ignore them anyway.
marty085
Postby marty085 » Thu Oct 27, 2011 11:36 am
If you don't care for the alarm, leav the horn out and just use it for central locking. As mr morlock says, nobody listens to them and they all sound the same. I nearly did this until I saw how complex the wiring was on my aftermarket and not matching the manufacturers manual so I didn't know what to disconnect.
honki3rider
Postby honki3rider » Thu Oct 27, 2011 11:55 am
The module is currently sitting in a box in my room now. Ahh, the sound of serenity. Will probably end up getting another alarm fitted in just for a piece of mind.
marty085
Postby marty085 » Thu Oct 27, 2011 12:51 pm
Seriously my aftermarket alarm p15535 me off sometimes, it is so easy to bump the buttons and inevitably set it off. but central locking is priceless.
