NB8B radio change to single din
land864
Postby land864 » Fri Oct 14, 2011 12:27 pm
Wanting to change the radio in my daughters 2001 Ford Laser LXI ( a radio that looks pretty much identical to my NB8B radio) from the double Din to a single DIN type.
1. Do I need a special tool to remove it?
2. Does someone make a new one piece panel to facilitate the conversion to end up with a single DIN radio and change compartment etc under or over?
Pete
de Bounce
Re: NB8B radio change to single din
Postby de Bounce » Fri Oct 14, 2011 1:28 pm
If it is near identical to the NB8B (Mazda-Ford family) have a read of this.
viewtopic.php?f=78&t=28063
Motorkhana Video
BadBong
Postby BadBong » Fri Oct 14, 2011 2:27 pm
Pete, can you post a photo up?
If it's am enclosed DIN space like the NCs then it'll be more difficult. Either way, you'll need to resource a single din compartment to fill the gap.
SKYHI
Postby SKYHI » Mon Feb 06, 2017 4:47 pm
Revivng an old thread :)
I have purchased a single din bluetooth unit for my SE, and want to replace the stock double din headunit with it and some gauges as per the photo below. I read through the thread mentioned above, but it's quite old and a lot of the photos are missing. The wiring adapters sound like a good idea, so thought I'd ask if anyone knows the best place to source these currently? Also, what other parts will I need to complete the conversion?
Cheers Paul.
Nevyn72
Postby Nevyn72 » Tue Feb 07, 2017 7:50 am
Given that's my car in the image above I suppose I'd better answer..... :mrgreen:
Parts used were;
- cradle for the single DIN radio (supplied with the radio)
- 3 gauge, single DIN, gauge holder (sourced from MX5 parts in the UK)
- 2 cable adaptors, Mazda -> Universal & Universal -> Alpine. Unfortunately there was no direct Mazda -> Alpine adaptor available for my vintage of car. (both sourced from eBay)
SKYHI
Postby SKYHI » Tue Feb 07, 2017 11:24 am
Thanks for the reply Nevyn, hope you didn't mind me using your photo :)
Is this the Gauge holder you used? Says it's for below the radio, but assumed it worked ok where you installed it?
http://www.mx5parts.co.uk/instrument-ho ... -1829.html
Otherwise there's this one.
http://www.thompson-automotive.com/cata ... 029659.htm
Wiring adapter/s are the way to go for sure, just need to source the right one for my Sony headunit I guess. Hopefully pick it up today and then I can see what connection I have.
davekmoore
Postby davekmoore » Tue Feb 07, 2017 12:32 pm
It might be handy for you to know that I'm about to de-audio my car, which currently has a good Alpine single DIN head unit with all that's needed to install it apart from blanking plate. Can all be had for a fair price.
Also about to remove cruise control.
Postby hks_kansei » Tue Feb 07, 2017 2:10 pm
The adapters can also be purchased at autobarn etc.
They work well, but double check the listing.
The one I bought, which was supposedly for Mazdas of my nb8a vintage wasn't even close to the plug.
I just cut off the oem plug and soldered the new Sony plug onto the loom.
SKYHI
Postby SKYHI » Wed Feb 08, 2017 10:39 am
Thanks Dave, but I have already purchased this Sony unit.
http://www.sony.com.au/electronics/in-c ... dsx-a400bt
This is the back of the unit.
Looks like I'll need the Aerpro APP072 Mazda Iso harness
and the Aerpro APP8SP3 Sony to Iso harness.
Sound right?
