Clearwater Headrest speaker install - '90 Na6
wassup
Postby wassup » Thu Oct 13, 2011 11:05 pm
Hi all,
This evening i installed a set of the Clearwater Headrest speakers and thought i might share my observations and a few pics of the install process.
Overall a very easy process. It took me alittle under 3 hours with distractions in between. To be honest the most time consuming part was running the cables under the carpet along the central turret and out the seatbelt bolt area's.
Removal of the center console and tombstone is well documented as is the actual installation process of the speakers (the installation guide is detailed) so i wont go into this.
Key tips are to take your time with the zips on the headrests and also the removal and reinstallation of the center console and tombstone. Given the age of all NA's the plastics etc are pretty brittle. Replacement parts for these particular area's arent cheap also!
My assessment of the upgrade, a big thumbs up! Its not going to win any SQ competitions but the speakers get pretty loud and sound pretty decent, unless your expecting bass, in which case you maybe disappointed. Adjusting the fade back to the front speakers shows just how good the headrest speakers are as the 2 speaker setup suddenly sounds very flat and directional.
Hopefully the weather this weekend will be nice enough to get the car out for a drive with the top down so i can see how much better it is at speed!
I hope this helps anyone considering a headrest speaker upgrade or is wanting to get a feel for the installation process.
Picture of the kit as it arrived from Clearwater. The kit comes with both a full harness and half harness that can be used if your Mx already has the cabling under the seat. Clearwater
recommends the use of the full harness as a number of Mx's have been known to have left the factory with incorrect wiring which results in poor SQ.
Picture of the Clearwater harness plugged into the back of the headunit. Its a plug and play affair and couldnt have been made easier. The speaker terminals are also a no brainer
with different sizes for each polarity to ensure you dont wire it wrong!
Full harness plugged in and ready to be tucked under the carpet.
taping the harness to a straightened coat hanger makes running the cables under the carpet easy. It also helps when running the cable up each seat back.
Cable comes out where the seatbelt bolts are located and runs straight up the back of each seat
I was sure my car wasnt pre-wired until i found this cable!
Peeling back the headrests uncovers the places for the speakers
Coat hanger once again helps get the cable from the back of the headrest to the front.
1990 NA6
Civic Type R
emily_mx5
Re: Clearwater Headrest speaker install - '90 Na6
Postby emily_mx5 » Fri Oct 14, 2011 10:11 am
How good are they! I did this on mine as one of the first mods, and I couldn't recommend these enough (apart from bass ofcourse)
Now we wait for summer :)
Jace
Postby Jace » Sat Oct 15, 2011 2:15 pm
So you've now got a loose wire running up the back of each seat? Or can it be ran within the seat?
I'm considering buying splits and chucking the tweeters in the headrests. AFAIK generally the idea with tweeters is to have them pointing at your ears. 8)
Might get too much left treble and not enough right treble though, that's my worry. Stock door speakers are well and truly past it.
emily_mx5
Postby emily_mx5 » Sat Oct 15, 2011 5:56 pm
On mine it is within each seat.
wassup
Postby wassup » Sun Oct 16, 2011 12:10 am
Jace wrote:So you've now got a loose wire running up the back of each seat? Or can it be ran within the seat?
The cable runs up the back of each seat internally, check out the last picture. Otherwise it'd look way to ghetto
As for tweeter placement. The correct way is actually to have them located as close to the mid bass woofer in the doors. Typically within a few inches pointing rearwards. Treble is way too directional so probably wouldnt be best suited to locating in the headrests.
The clearwater kit is stereo in each headrest.
1990 NA6
Civic Type R
yem11n
Postby yem11n » Mon Oct 17, 2011 1:51 pm
Nice write up again.
Makes me want to order the 8" replacements for my car from them.. :evil: aahhh
Yemin
Darkness BLACK 130i (2006) Sold
Tiny BLACK SE (2005)
A few mods.
BLACK CX5 Akera 2015
Stock as.
jlo8872
Postby jlo8872 » Tue Apr 17, 2012 5:22 pm
Anyone got an idea (images would be very much appreciated too) on the headrest speaker harness for an NA8?
J.
1997 NA8 BRG LE.
"You're a pack of Arseholes"
- Jim Richards responds to a booing crowd of the 1992 Bathurst 1000.
falconsforge
Postby falconsforge » Sun Apr 22, 2012 2:06 pm
We have had the clearwaters in our NA for a year or so now. Great little units. The Bose rears in the new NC are nowhere near as good.
89 NA Silver
11 NC Coupe Special Edition Aluminium
Users browsing this forum: Bing [Bot] and 7 guests
