Disconnecting the mass air sensor electrical connection.
- CoachOz
I'm wanting to fit a new intake which means disconnecting the mass air sensor electrical connection. Do I have to disconnect the battery or simply have the ignition turned off? I'm concerned that if I disconnect the battery I'll have to re input the radio code and I don't know it!
- Learner Driver
Re: Disconnecting the mass air sensor electrical connection.
Turn off ignition and remove key. That way no way its on by accident. Disconnect sensor.
- CoachOz
Thanks, that's what I thought and it makes sense
