I want to make it so.. the following TURNS OFF WHEN I TURN MY CAR OFF
-Healights
-Taillights
-Electric Mirror Controls
-Dash Lights
Another question is.
Im gonna put a ENGINE start button in my car to.
I'm gonna make it light up and everything when the key is turned this is easy, im just curious how could i STOP the switch from working AFTER the car has been started?
Technical Question
- slimx
- Vehicle: NB8B - Turbo
- Jeo
Re: Technical Question
No auto electrician myself but I'd look at wiring a relay between the main wires for all of those different things, triggered by the accessory wire from your ignition.
No idea on the start button sorry.
I've got one. You should check out my video on YouTube :p
the light is usually powered by by the cigerette lighter light circuit, which usually only comes on when the lights are on.
It is apparently possible to get the button to stop working once started, but it was too complicated for me, so I didn't bother. I also didn't wire up the light, coz I couldn't think of anything more annoying than a red light on all the time.
If it's in the cigerette lighter area, it's hard to push accidently. Food for thought.
If you need to know which wires are used for the button, let me know, and I'll upload a pic for you.
Cheers.
Cheers.
This is my MX5. There are many like it, but this one is mine. My MX5, without me, is useless. Without my MX5, I am useless.
The MX5 Drivers Creed.
- slimx
An idea i had was to run the head units ignition wire to a power distributer and use that for all the lights??
But cbf trying would it work?
Does the headlights power and earth turn on by the switch or only the power?
- Jeo
slimx wrote:An idea i had was to run the head units ignition wire to a power distributer and use that for all the lights??
Jeo wrote:wire a relay between the main wires for all of those different things, triggered by the accessory wire from your ignition.
- slimx
- joe5084
- Learner Driver
slimx wrote:I want to make it so.. the following TURNS OFF WHEN I TURN MY CAR OFF
-Healights
-Taillights
-Dash Lights
I would wire the switch light to ignition and the alternator warning light terminal and it will operate just as the alternator warning light.
Joe 2005 Winning Blue NC
I am not even sure I understand any of this. How hard is it to turn off the cars lights. Ignition off - lights turned off. Whilst some may have never experienced it but an amateur at auto electrics is not a good look- when the wire burns it is a bit scary. A run down on auto electronics read something like "How to diagnose and repair automotive electrical systems- Tracy Martin.
- joe5084
- Learner Driver
joe5084 wrote:slimx wrote:I want to make it so.. the following TURNS OFF WHEN I TURN MY CAR OFF
-Healights
-Taillights
-Dash Lights
I forgot the top section a set of ignition controlled relays for each except tail lights as that is a legal requirement to operate without the key
- slimx
legal shmegal i dont care.
I do what i want, if i get done for it then i worry about making it legal.
