Interior lights and tail lights gone...
doogle
Postby doogle » Sun May 29, 2011 5:46 pm
Hey everybody,
I've lost all my interior lights and tail lights on my NA6 :(
Headlights and indicators are ok. The fuses are all ok (TAIL and BTN).
I'm not sure if they both went at the same time, but the wiring diagram suggests it's all connected together.
Before they went I noticed the instrument lights would flicker on and off while driving, gradually becoming more off.
Could it be old wires touching/grounding?
Any ideas or key places to look?
I pulled out the radio and checked behind there today, there doesn't seem to be anything wrong there. The red/black wire that connects the interior light system never had anything connected after the head unit got installed, but everything worked. I thought maybe it was touching something but it was fine. Head unit's been in there for three years anyway...
Any advice much appreciated, thanks!
bensale
Re: Interior lights and tail lights gone...
Postby bensale » Sun May 29, 2011 7:28 pm
It's silly and it sounds like you have a bigger issue than me, but have a look at the dimmer switch. If I have the dimmer on full brightness the dash lights will go out so I have to leave it just off full.
www.othersideproductions.com
joe5084
Postby joe5084 » Fri Jun 03, 2011 3:15 pm
I haven't seen a NA diagram just a NB and there is a tail light relay that controls all tail, park and dash lights if this fails it will leave the headlights working and the tail fuse in tact. worth a shot.
Joe 2005 Winning Blue NC
chewy
Postby chewy » Sun Jun 12, 2011 3:18 am
since this post is almost a month old you probably have had it sorted but for those who dont know;
your problem would probably be the combination switch that turns on your accessories. remove the switch and pull it apart and clean the contacts or replace the whole thing. pretty common problem on old mazda switches
