Anyone know of a Mazda which has the same sort of window switches as a NB that do AUTO UP AND DOWN?
Want to swap the switches around so i can do the windows easy when putting roof up and down.
Cheers....
Power Window Auto UP AND DOWN
- dave2221
Re: Power Window Auto UP AND DOWN
I think this kit only puts the windows up but i'm sure there's an after market kit that will do what you want.
- dave2221
thanks but not quite what i was looking for
On my NB, the drivers window has auto down and the passengers does not
it is my undestanding if i buy a 2nd drivers switch, and replace it with the passengers switch they will now both be auto down....
so what i am asking, is there any later model mazda, which has interchangable switches, that do the auto up and auto down?
or am i barking up the wrong tree?
dave2221 wrote:thanks but not quite what i was looking for
If you pull apart your existing window switch, you'll see on the circuit board that the driver-side switch has a lot more components associated with it to control the Auto functionality. Both physical switches are connected to the same circuit board so you cannot simply swap in another driver-side switch.
- dave2221
ahh rightio then
thanks.
thanks.
- aviper4u
i have an NB and both the driver and passenger arent auto though would love this option.
was it an optional extra when new?
It wasn't on early NBs but you can buy the later NB switch to add the drivers side function.
- dave2221
guys
i think this is the part i have been looking for:
it converts your standard buttons to auto up/down, and also allows them to go up when you lock the car..... nice
i have contacted teh seller, and when they reply i might consider ordering a few, if some other people are interested.
http://www.miatamania.com/Shop/ViewProducts.aspx?PlateIndexID=33273
