How to run your own ECU check
Posted: Mon May 09, 2011 6:48 pm
by slimx
Hey i found a thousand posts about it on the miata.net forum but they all just say connect the pins .. together with a paper clip theres like 20 PINS there! lol
Is there a simple way someone can explain to me how to run a quick self ecu check i believe it has something to do with checking the engine light etc..
NB SERIES 2
Re: How to run your own ECU check
Posted: Mon May 09, 2011 6:59 pm
by Hjt
drive to mx5mania, ask them to show you it only took them a couple of seconds to test mine at last service interval
Posted: Mon May 09, 2011 7:04 pm
by gslender
Found this...
http://www.miata.net/garage/faultcodes.htmlAfter warming/running, your stop, then short GND and TEN and then turn the car on to ignition only. The "CHECK ENGINE" light flashes to report the code.
Simple enough really....
G
Posted: Mon May 09, 2011 7:07 pm
by slimx
that sounds easy lol i might go give it a try tomorrow when its not so cold lol
thank u
Posted: Tue May 10, 2011 1:26 am
by Okibi
Since yours has ODBII just find someone with an ODBII reader.
These are very cool but the iphone software is a little expensive
http://www.thinkgeek.com/gadgets/car/dcf4/
Posted: Wed May 11, 2011 12:05 pm
by Caffeine
gslender wrote:Found this...
G
Except we didn't get a check engine light
You need to hook up an LED with current limiting resistor between B+ (straight from the battery, so will source lots of current if you wire it up wrong)and the FEN pin in the diagnostic box.
Procedure explained well here :
http://www.miata.net/garage/Engine_Diagnostics.html
