hi all,
My front left indicator is not working and i changed the bulb to no avail......
I assume its the flasher unit that is stuffed....
Dose anyone know which and where i find the unit / box thingy in my NB8a ???
indicator not working
- wazman
ilovedrift.com
Re: indicator not working
check to see if there is power to the bulb ie the terminal- is the same side rr working? Might be a fuse which is the usual first thing to check.There can easily be a bad connection power or earth. Refer also owners manual which is very handy to have- it always gives info on replacement of fuses bulbs etc.
On the NA8 the flasher/ hazzard box is grey, is 6x5x3 cm, & is mounted on a silver bracket along with a black buzzer/ timer box 5x3x3 cm. On the NA8 they are under the dash on the driver's side.
- wazman
