What size is the audio in a 1997 NA8
snshami
Postby snshami » Thu Jan 27, 2011 1:51 pm
Hi, my 1997 NA8 has a CD player and a radio. Can someone please confirm that they are both single din and in combination are double din. Which car had the 1.5 din units. Does anyone know if I can get a 1 Din cubby if I replace them both with 1 single din unit. I am trying to get it to play usb and bluetooth audio.
1997 NA8 Neo Green - Limited Edition
Garry
Re: What size is the audio in a 1997 NA8
Postby Garry » Thu Jan 27, 2011 8:39 pm
If you didn't option the CD then the stock radio/cassette was single DIN with a 1 DIN plastic pocket underneath. The 96.5/97 NA8 also came with the correct sized cutout in the console facia for an aftermarket single DIN head unit to fit in perfectly.
snshami
Postby snshami » Thu Jan 27, 2011 11:35 pm
My car has the CD player as well as the radio/tape unit. I was going to swap out both. Should I sell them or keep them. Would I get anything for the original units. They both work.
Postby Hammer » Fri Jan 28, 2011 8:50 am
MX5 Parts UK are currently having specials on several audio parts on both single & double DIN.
http://www.mx5parts.co.uk/product_info. ... cts_id/119
http://www.mx5parts.co.uk/product_info. ... ts_id/1518
zossy1
Postby zossy1 » Sun Jan 30, 2011 9:48 pm
snshami wrote: Which car had the 1.5 din units. Does anyone know if I can get a 1 Din cubby if I replace them both with 1 single din unit. I am trying to get it to play usb and bluetooth audio.
My 94 Clubman had a 1.5 DIN radio/cassette. I still have the unit but will be replacing it with a single DIN unit to give me space for a 3x 52mm gauge facia (single DIN) when I turbo the car.
Most single and double DIN units over $250 will give you USB and bluetooth. You can probably get these features for less if you hunt around.
