New owner - audio problem
Magnum
Postby Magnum » Mon Jan 17, 2011 12:23 pm
Hi all,
Just picked up an '07 NC on Friday and loving it. slight problem though - the Bose audio system occasionally cuts out down to just one or two speakers on the drivers side with very poor crackly sound. This sound continues even after the stereo is switched off.
Its going back to the dealer to look at shortly, but just wandering if this was a common problem?
the car has the Mazda Bluetooth system fitted too and although this works fine, I suspect it has something to do with that - the same speaker(s) are used.
thanks for any help
Magnum :)
snshami
Re: New owner - audio problem
Postby snshami » Fri Jan 28, 2011 6:40 pm
It sounds like a loose connector. Hopefully the car is still under warranty.
1997 NA8 Neo Green - Limited Edition
