Hey,
Yes i know yet another AC question though its hot so fair enough......
Is it normal for both the radiator's fans to turn on when the AC is on, stupid question though just noticed this as changed drive belts and was testing with bonnet open.
Also any simple ways to see how can get it colder as just had it gassed under a year ago.
cheers
AC and thermo fans
- aviper4u
AC and thermo fans
- joe5084
- Learner Driver
Re: AC and thermo fans
aviper4u wrote:Hey,
cheers
Yes this is normal. When you switch on the AC you need air through the condensor whenever the compresor is running to remove the heat from the refrigerent being circulated.
Joe
Joe 2005 Winning Blue NC
- aviper4u
good to hear
though i wonder do the fans turns off once the car is at speed? ie freeway...
anyways either way thanks for insight
- joe5084
- Learner Driver
aviper4u wrote:good to hear
The fan is on while the AC is on, the AC overrides the fan allways regardless of temperature and vehicle motion I hope this helps you.
Joe
