No problems with 6.5" speakers.
Coaxials (multiple speakers in the one bracket) are an easier but worse option when compared to separate components. If you can be bothered to install separate speakers for the woofer and tweeter I'd recommend going with that; if you can't be bothered, 2way coaxials are often less bad than 3ways.
What size speakers fit an NA6?
- Jeo
- muzzy66
Re: What size speakers fit an NA6?
I've found that 6" is probably close to the limit.
I've got 5.75" Scanspeak Revelators in there right now on custom baffles, and there isn't a lot of room left diameter-wise. That said, my baffles are cut for a flush mount, so that takes a bit more space also.
Without a flush mount cutout i'd say you would probably squeeze in a 6", maybe a 6.5" - anything bigger then that and you'd need some custom pods (unless you dodgy install it, which i wouldn't recommend).
Car
2004 Alfa Romeo 147 GTA
Audio
Source: Clarion HX-D2
Speakers: Focal 165WRC
Amp: Zapco Reference 350.2
Sub: DLS Nordica 10i
Amp: Helix H1000
Car
Audio
Amp: Helix H1000
