NA clear bumper side markers/reflectors fit issue
Varjak
Postby Varjak » Mon Jan 03, 2011 2:13 pm
Hello everybody!
I've recently purchased some clear front bumper reflector/side markers for my green NA to go with the clear side repeaters (circular) and side front lamps. On fitting, I've discovered that they don't sit flush to the bumper, the rear end pokes out and is over-flush even when screwed down tight. It looks odd, see pics attached.
On inspection, it seems that the original, Mazda orange units are thinner and of a slightly different form to the replacement clear ones which I have bought from the US.
Have any of you guys found this issue when purchasing/fitting clear side markers? I'm wondering if I've bought some that only work with US spec bumpers...
If you've found clear side markers/reflectors at a good price (for front and back) that FIT, can you point me in the right direction. Thanks everyone!
Varjak 8)
1997 NA Neo Green Limited Edition.
Re: NA clear bumper side markers/reflectors fit issue
Postby Mr Morlock » Mon Jan 03, 2011 3:14 pm
clear reflectors mounted on the side are not legal but I guess people know that . If these are aftermarket items they may very well not be dimensionally identical to OE units. You might be able to pack out the low side to even up the appearance when fitted- could this be done with soft gasket material?
Steampunk
Postby Steampunk » Mon Jan 03, 2011 6:35 pm
Are they correct fitment front and rear? They have a slightly different shape, one is fatter than the other.
Varjak
Postby Varjak » Mon Jan 03, 2011 9:48 pm
Yeah, checked them on the rear as well and the fit is also bad, the parts look deliberately that shape.
Has anyone out there bought some clear side markers that fit well? If so, where did they get them from please?!
bensale
Postby bensale » Mon Jan 03, 2011 10:20 pm
1red5 wrote:Are they correct fitment front and rear? They have a slightly different shape, one is fatter than the other.
x2
I have the IL motorsport ones, I initially had the same problem as you because I assumed that they were the same back to front, that isn't the case and after swapping them around no problems. If yours aren't different front to back I'm not sure what it could be...
www.othersideproductions.com
Postby Jeo » Tue Jan 04, 2011 12:14 am
I have IL Motorsports ones and like Ben, I had the same situation. Swapped them front to back and all was well.
