I have a Series 2 NB, with an aftermarket alpine head unit installed.
I also have an amp & a sub I'm yet to install sitting around.
I need to run the cabling from the head unit, back to the boot where the amp and sub will live.
I can connect the amp to the battery fine, but how do I run the cabling from the head unit/interior into the boot?? is there a hole in between the interior and the boot or do I need to make one?
thanks for your help!
help - how do I get cabling from my head unit to the boot?
- Jeo
Re: help - how do I get cabling from my head unit to the boo
Two large holes already there, one down each side of the boot. Have a look from the inside of you boot at the very back on either side or under the carpet on the parcel shelf and you'll figure it out fairly quickly.
great! thank you.
