Auterra Dash Dyno
Sailor
Auterra Dash Dyno
Postby Sailor » Fri Dec 17, 2010 1:25 pm
Have had my Dash Dyno in the car for the last few days and can tell you anyone who has an aftermarked ECU or Piggyback, that this is a great bit of gear.
http://www.dashdyno.net/product/dashdyno.html
It will report and log bloody near every ODBII output.
I'm using it in conjunction with my Xede piggyback and looking at fuel trims/AFRs, I'm tickling the mixture at various RPM and loads to get closer to zero trims than the -8.7% that I originally saw.
The unit has a bunch of programmable warning lights that will work over the top of each other if required to give AFR out of range, shift lights, oil pressure warning, knock sense and anything you might like to use.
Software is easy to use.
Highly recommended.
BTW I have a Scanguage for sale....
Rob
