Swapping the odometer
Posted: Mon Nov 08, 2010 2:19 pm
I have another gauge cluster I would like to put in the car, so in the interest of maintaining the odometer, is swapping it to the new cluster a difficult thing to do? Can this even be done with an NA odometer? In searching past threads I see that Sliq has done an Odo transplant in the past, but I imagine that might be quite different on the NB.
The cluster to transplant in is from a Japanese car and has AWD gauge faces, so would like the needles to read correctly as the the faces go to 200km/hr only.
I'm presuming that the best way to maintain needle integrity is to use the the Japanese cluster, rather than try and make the AU cluster in my car move the needles at a different rate?
If I can't do this swap and have correct needle movement I'll pass on the gauges install... I really bought the cluster for the needle caps
