wired one
Posted: Fri Oct 22, 2010 8:47 pm
by funmx5
has anyone had this sometimes by wipers ,electric windows and reverse lights dont work on my na only does it sometimes
may be common earth ?
Re: wired one
Posted: Sat Oct 23, 2010 12:22 am
by 93_Clubman
from memory the fuses those items are all located in the fuse box under the drivers side dash behind the bonnet release, so there might be a lose earth or two there. alternatively could be an earth or two elsewhere as the early NA6s can suffer from this now that they're 21!
Re: wired one
Posted: Sat Oct 23, 2010 8:32 am
by funmx5
thanks for the information ,do you know if there is wiring diagram on anywhere on the web?
Re: wired one
Posted: Sat Oct 23, 2010 11:05 am
by 93_Clubman
Re: wired one
Posted: Sat Oct 23, 2010 1:12 pm
by funmx5
excellant and thanks!!!
Re: wired one
Posted: Sat Feb 05, 2011 5:07 pm
by funmx5
thought id give a update on this one removed power window switch and cleaned the contacts in the switch ,since then i not had a problem with either
