has anyone had this sometimes by wipers ,electric windows and reverse lights dont work on my na only does it sometimes
may be common earth ?
wired one
Re: wired one
from memory the fuses those items are all located in the fuse box under the drivers side dash behind the bonnet release, so there might be a lose earth or two there. alternatively could be an earth or two elsewhere as the early NA6s can suffer from this now that they're 21!
- funmx5
Re: wired one
thanks for the information ,do you know if there is wiring diagram on anywhere on the web?
red na6
cx7
cx7
Re: wired one
here you go: http://neomiata.com/garage/index.php
- funmx5
- funmx5
Re: wired one
thought id give a update on this one removed power window switch and cleaned the contacts in the switch ,since then i not had a problem with either
red na6
cx7
cx7
