Need help with window problem
Posted: Sun Oct 03, 2010 12:50 pm
I just replaced my window switch in my NB8A( BIG thanks to Fattima ) and still my drivers side window will refuse to go down
Ive checked the main window use and that is fine... My Question is that: Is there any other fuse appart from the main fuse that protects the window circuit or are there any relays that could have burnt out
When my switch decided to retire the switch was stuck in the up position for a while and is there any chance this could lead to the motor to burn out
So before i change the motor over i want to make sure that its the motor thats toast and nothing else Whats the best way to test the motor to see if its buggered also
Sorry about all the Q's but ive never had this before on any of my MX's so keen to know and of corse work out whats wrong with my drivers side window
Any help would be GREATLY appreciated
Cheers,Mark
Cheers,Mark
