Central Locking Motor Broken
zephyrus17
Postby zephyrus17 » Thu Aug 19, 2010 1:02 pm
My door recently won't lock and open and I thought it was the spring's fault because I found the old one broken on the bottom of the door. I replaced that, and found that the central locking won't work. Basically when I press the lock button on my remote it attempts to go to lock, then just gets jammed or something and has to unlock. Will I have to get the motor replaced or is there a much easier solution?
Momo (aka 1990 white NA6)
Re: Central Locking Motor Broken
Postby Jeo » Thu Aug 19, 2010 2:46 pm
I'd suggest pulling the door trim off and having a look. You'll quickly see whether the actuator is trying to do it's job but getting stuck, or if it's just not working at all.
zephyrus17
Postby zephyrus17 » Thu Aug 19, 2010 2:55 pm
the trim is off. When trying to manually lock the door from the inside it's very stiff. And won't stay in the locked position. Because of the bad angle I can't really see what's the problem.
