NC 2006 CD Stacker Stuck....Help
MR5000
Postby MR5000 » Fri Jul 30, 2010 5:36 pm
Hi gang,
I have a 2006 MX5 with the 6 stacker system.
The problem I have is that it says CHECK CD and won't play them won't eject them won't do anything except say CHECK DC
There's 6 cd's in there and I can't get them out, What do I do..
Please help, it's doing my head in.
Pauly
Uploaded with ImageShack.us
"Life's pretty straight without... Twisties".
Winning Blue 2006 MX-5
MR5000
Re: NC 2006 CD Stacker Stuck....Help
Postby MR5000 » Fri Jul 30, 2010 9:39 pm
Has anyone heard of this problem on any other website or any one else's 5..
JBT
Postby JBT » Fri Jul 30, 2010 10:06 pm
Have you tried pressing and holding the eject button for more than 2 seconds?
Fatty
Postby Fatty » Fri Jul 30, 2010 10:15 pm
if that fails, take it to the local mazda dealership?
MR5000
Postby MR5000 » Fri Jul 30, 2010 10:22 pm
Yeah JBT I've tried holding all the buttons and pressing them together and so on..
There must be an answer out there better than take it to Mazda and get handled $$$, Thanks anyway Fatty.
Postby Mr Morlock » Sat Jul 31, 2010 10:28 am
you could take it to a auto audio business of which there are a number - they must see these probs very regularly. Most businesses will advise their charge rates or estimates of repair cost. If in fact there is a very simple way of expelling the cd's ( what caused it) then the charge might be nominal. Another thing you could do is remove the unit completely and present to a repairer.
Postby bruce » Sat Jul 31, 2010 10:39 am
I kept thinking it was a stacker (the 6 cds are inside the head unit).
Ummm, perhaps disconnect the battery and let it sit for a couple of minutes?
Sailor
Postby Sailor » Sat Jul 31, 2010 10:47 am
Last resort..there's one on Ebay @$399
http://myworld.ebay.com.au/original_car_stereos/
Rob
taminga16
Postby taminga16 » Mon Aug 02, 2010 12:52 pm
I am with Bruce in interrupting the power supply but remove the audio fuse and save yourself the bother of resetting everything (ABS, DSC TSCC trip meters etc). Once the power is disconnected leave it all and make some coffee before reconnecting.
God Luck.
Greg.
MR5000
Postby MR5000 » Mon Aug 02, 2010 6:30 pm
taminga16 wrote:I am with Bruce in interrupting the power supply but remove the audio fuse and save yourself the bother of resetting everything (ABS, DSC TSCC trip meters etc). Once the power is disconnected leave it all and make some coffee before reconnecting.
God Luck.
Greg.
What do you mean by resetting the ABS etc..
I've just disconnected the battery now and i will leave it for awhile..
JBT
Postby JBT » Mon Aug 02, 2010 7:26 pm
You'll just need to reset the DSC - see the owners manual.
MR5000
Postby MR5000 » Mon Aug 02, 2010 7:27 pm
Reconnected the battery after an hour and still the same ( CHECK CD ) minus all the preset stations..
Postby Mr Morlock » Mon Aug 02, 2010 8:40 pm
you know what the answer is
taminga16
Postby taminga16 » Sun Aug 08, 2010 1:05 pm
Hi Paul,
Have you had any joy in sorting the problem with your CD player?
Greg.
MR5000
Postby MR5000 » Sun Aug 08, 2010 7:45 pm
Yeah I have , I was driving along Parramatta rd listening to the radio, sitting at the lights I pressed
eject CD and the 1st cd came out......Wow 5 more hits and they all came out. Cool
They were all original CD's so I don't know what the problem is..
Anyway I havn't put them back in yet , I'll give them a clean up and see how I go.
Thanks Greg and crew for all your help.
