Fan relay - plug melting
TieNN89
Postby TieNN89 » Sat Jul 24, 2010 10:08 pm
Hi all
I've got a relay under my dash (next to the fuel pump relay) from what I can tell it's for the interior fans and it is melting the plug slowly
Anyone got any ideas why this would be happening and what I can do to fix this?
The relay side of things looks perfectly fine
From the looks of things one of the pins in the plug is getting hot and the plastic surrounding it is melting and a bit of the insulation on that wire is too
Locutus
Re: Fan relay - plug melting
Postby Locutus » Sun Jul 25, 2010 12:01 am
first, check that the correct fuses are being used on the circuit(s) in question.
if they are correct, your problem is most likely dirty contact(s) on the relay and/or socket. resistance = heat.
TieNN89
Postby TieNN89 » Sat Aug 21, 2010 10:41 pm
Locutus wrote:first, check that the correct fuses are being used on the circuit(s) in question.
Yes correct fuse
The relay turns on as soon as it's in the ON position
The wire that is melting is the output wire
Also the relay is getting warm too :S
Locutus
Postby Locutus » Mon Aug 23, 2010 6:43 pm
Locutus wrote:your problem is most likely dirty contact(s) on the relay and/or socket. resistance = heat.
try cleaning the contacts on the relay and in the socket.
if it's just a standard relay (not one with a fancy expensive socket) i would just cut the socket off and solder a new one in it's place. you will need to address the issue of melted wiring anyway.
TieNN89
Postby TieNN89 » Mon Aug 23, 2010 6:55 pm
Yeah it's not a standard relay
But the plug looks pretty standard though
I'll take a picture of it
I'll clean the contact with some CRC Contact Cleaner
