front lights are dead.
StanTheMan
Postby StanTheMan » Thu Jul 01, 2010 11:07 pm
OK
Patchys front lights died tonight.
headlights are up
will not come down when switched off.
lights inside work.
no high beam or low beam.
rear lights & number plate lights work.
where do I start checking?
its an NA6
Locutus
Re: front lights are dead.
Postby Locutus » Thu Jul 01, 2010 11:18 pm
start with fuses, then relays
check the block in the engine bay first.
StanTheMan
Postby StanTheMan » Fri Jul 02, 2010 10:34 am
yep its a blow fuse indeed.
so I replaced it with another & it worked for 2 seconds before it blew again.
looks like the bug hunt under the butchered dash is the go.
I hate electrics. :?
StanTheMan
Postby StanTheMan » Sat Jul 03, 2010 9:31 pm
so Off to Supercrap it was this morning to get some more fuses & some spare ones because I'm sure to blow a few to fix this.
I replaced the blown 30 amp one with a 40 amp one so hopefully it would last a little longer as I was told this was something a little more major.
Look for melted wiring I was told in no uncertain terms.
So As I'm switching the light switch on & off I notice smoke appearing from under the drivers side light. bingo.
unbolt the covers & the plot thickens.
the plug is melting. Its melted enough to short the system. Its been melting slowly for some time.
so a new plug was found & re-wired.
a new plug with appropriate size wiring was attached. It came from a 1965 Holden Premier.
and the lights are back in action. As well as being a little brighter than before.
relieved & happy. And many thanks to a sparky friend who drives a beautiful 1965 Holden Premier.
Benny
Postby Benny » Tue Jul 06, 2010 3:52 pm
Glad to hear you fixed it Stephan.
On another note, I see you going to work quite often in the mornings when you turn into River Rd at Greenwich (like this morning).
For a shop owner, you're lucky to get to start work so late!
Postby sliq » Tue Jul 06, 2010 4:49 pm
don't you just love easy fixes :mrgreen:
StanTheMan
Postby StanTheMan » Fri Jul 09, 2010 12:15 pm
Benny wrote:Glad to hear you fixed it Stephan.
All is not as it seems. :lol: :mrgreen:
i'll have to start watching out for you.
I absolutley despise electrics.....& freak at the prospect of any electrical issues.
