NA6 Hardtop demister cabling V NB8 softop w/demister
miatas76
Postby miatas76 » Tue Jun 01, 2010 2:23 pm
Hey y'all, thought i'd post a new topic rather than latch (pardon the pun) onto someone elses thread.........
Will a NA6 with hardtop demister cabling plug into the NB soft top with rear window demister if and when i decide to install? how does this work?
'92 NA6 :NA6:
I'm an alien, I'm a legal alien
I'm a Melburnian in Brisbane
Postby 93_Clubman » Tue Jun 01, 2010 8:44 pm
this should answer most if not all your questions: http://www.miata.net/garage/hardtop/
also 'Hammer' put together a great write up here:
viewtopic.php?f=57&t=34566&start=15
viewtopic.php?f=57&t=34566&start=30
this might also contain a few answers:
viewtopic.php?f=18&t=41368
Benny
Re: NA6 Hardtop demister cabling V NB8 softop w/demister
Postby Benny » Fri Jun 04, 2010 3:40 pm
Why worry about the rear screen demister?
Just use your air conditioning.
It works a lot better than the rear screen heater.
Wuey
Postby Wuey » Fri Jun 04, 2010 6:06 pm
I concur with Benny. I rarely had trouble with mist on the rear window in my previous NA by using either the flow-through ventilation feature or if the mist is built up heavily which was rare, I just hit the a/c button for a few seconds to clear it. Besides, it helps to prolong the life of the a/c system if you work it a few times a week even in winter. The a/c in my previous NA was still in perfect condition save for one regassing and retrofitting to modern refrigerant even after 20 years of service.
It's a real pain to plug or unplug the demister in the confined quarter where the female plug sit in my MSM so I just leave it unplugged most of the time.
Image 2004 SE
Wuey
Postby Wuey » Fri Jun 04, 2010 6:37 pm
A few more tips. Always keep your interior glass area and your rear vision mirror super clean. If you have mist, never ever use a rag or worse, your hand, to wipe it off. Doing so will just introduce grease on the surface area. I go berserk whoever uses his or her bare hand to touch my glass area. I just use ordinary dish washing liquid thinned down to clean the glass followed with a wipe using paper towels. Then I use a sponged soaked with one part methylated spirit mixed with two to three parts water to wipe the glass again and dry off with paper towels. This treatment cuts down misting problem considerably. Do this ritual every two to three months and you can forget about any fanciful demister.
Image 2004 SE
