Hey guys,
my battery died as car been sititng since december in garage!
I went to repco, got a replacemet, same ampage etc, put them next to each other and same size.
however for some reason as I go to fit it, the clamp now wont go over it, tired many times (or am I just a 'tard?)
any chance someone can measure their battery or know the dimensions so I can take it back and get a proper sized one?
cheers
Chris
Battery size
Battery size
viewtopic.php?f=73&t=62834
Battery size
there are lots of posts on this subject- best advice is use the right battery - you cannot safely use a standard battery and some sellers have no idea of the right type and spec. Try as a search "mx52nv 9/11/08 " There is a stack of info and as Benny says you are far better off using the right one which lasts for many years.
Battery size
Dimensions of stock panasonic battery (cm) is W12.5 H16.0 L 23.5
And just incase you wanted to know its 9.514 kg
every ounce counts
- sliq
Battery size
wun911 wrote:Dimensions of stock panasonic battery (cm) is W12.5 H16.0 L 23.5. And just in case you wanted to know its 9.514 kg
sliq wrote:supercharge gold
MF43: 235x170x135 (LxHxW)
or
MF40B20DF: 195x202x128 (LxHxW)
From memory, both are slightly heavier than Panasonic, but it's on their website.
- sliq
Battery size
the supercharge comes with 3 years warranty.
make sure you buy from a good, reliable auto-electrician. who will actually make the effort to charge your battery
/or buy a trickle charger if your car is going to be just a weekender
