Blu ant for cars Brand suggestion
land864
Postby land864 » Thu Mar 25, 2010 12:34 pm
Any suggestions for a good brand of Blu Ant or other portable Bluetooth devices
Will be swapping daily drives between the MX and another vehicle
Also , has anyone made one that can transmit over your radio signal and utilise the in car stereo ?
Pete
Postby Hammer » Thu Mar 25, 2010 3:55 pm
I have a Blue Ant Supertooth 3. It works extremely well even with the roof down (side windows up).
It comes with 2 visor mounts (left clipped on the visor) which the unit simply attaches to using magnets. I regularly swap it between my MX5 and Pajero (That is until I got my 2nd unit a Uniden BTSC 1500 - see below).
It also support a lot of modern phone functions, like voice dialing. So I simply have to touch the call button once, the unit will prompt me (it even gives you an option on the voice - which accent and sex), then I simply say the command (ie. "Call") and name of the person / business that is already in my phone. Then it dials it. So it's trully a hands free set.
And when someone calls you, it will say the name of the caller (provided they're in your phone already and/or not private).
I recently purchased the Uniden BTSC 1500 which I got really cheap from catchoftheday.com.au. I'm trully impressed. It's slightly smaller and looks sexier than the Supertooth3, but it's not as easy to clip on and off as the BlueAnt. The clip is attached to the unit (and they only supply one). Though the unit has a blue backlit OLED display which displays status and numbers vividly. After 10mins of inactivity it will blank out - saving battery power.
It too supports modern phone functions, like voice dialing. And can support up to two different phones simultaneously.
I now have the Uniden in my MX5 due to its lighter weight (better for the flimsier visor of the 5) and left the BlueAnt in my Pajero.
I'm happy with either one but If I had to buy another one now, I'll get the Uniden - so long as the price is right.
de Bounce
Postby de Bounce » Thu Mar 25, 2010 4:57 pm
Please note that Blu Ant is a brand of Bluetooth devices
I also have a Blue Ant Supertooth 3.
It normally lives attached to my NB's sun visor and has not created any problems.
As stated by Hammer, it works well and comes supplied with two visor clips with the unit attaching to the clip with magnets.
If you want to transfer the device from one vehicle to the other, this mounting method might be the best.
Motorkhana Video
99MXV
Postby 99MXV » Thu Mar 25, 2010 9:02 pm
I sell Bluetooth devices and recommend the Supertooth 3 as well. There is also a new S1 Blueant that is slightly cheaper that would suit.
Wayne
Won't be long now... On the hunt for an MX5
land864
Postby land864 » Thu Mar 25, 2010 11:59 pm
Thanks all.
Ideas of cost please ?
Could it be mounted lower , say on the trans tunnel?
99MXV
Postby 99MXV » Fri Mar 26, 2010 7:44 am
They work at their best when on the visor as you should be looking up at the road when you drive. You will lose performance if mounted lower.
The ST3 is $149 RRP
The S1 is $129 RRP
I am sure someone will point you towards a cheaper online alternative.
MX5CHIC
Postby MX5CHIC » Fri Mar 26, 2010 1:45 pm
I use the blueant - works perfectly, I charge it about four times a year, loud enough and sensitive enough to use with the top down :D
Postby Hammer » Fri Mar 26, 2010 5:08 pm
land864 wrote:Thanks all.
I got my BlueAnt ST3 from JB Hi-Fi when they first came out. Cost me $119 when it was on special. They might be cheaper now.
The Uniden cost me $49.95 from catchoftheday.com.au during one of their usual 24hr specials. I think they usually retail for about $120 or so it says when I bought it.
land864
Postby land864 » Wed Mar 31, 2010 12:00 am
Thanks All
I will track them down
Postby Hammer » Wed Mar 31, 2010 1:58 pm
land864 wrote:Thanks All
If you're still keen to take a look at the Uniden Bluetooth kit that I mention above....1-day have then on special again for $59.99 (from $115). Click on this link http://www.1-day.com.au/products/A9MHCN0SC.
This deal is only valid till noon tomorrow (1st April) or till sold out.
land864
Postby land864 » Thu Apr 01, 2010 12:06 am
Bugger . I bought mine for $ 118 at 12.55 :roll: But work is paying for that one.
At that price though I will get one for the house manager :)
TieNN89
Postby TieNN89 » Sat Apr 10, 2010 11:20 pm
I've seen that Uniden unit
Its a very nice sleek looking unit
Do you have to switch these units on and off every time you leave the car?
My head unit has bluetooth but for some reason it seems like its incompatible with my Nokia 5800 but it worked fine with my previous Nokia 6110 :S
And I thought the idea behind bluetooth was to make things compatible and work together
One of the guys at work has the same problem with his Telstra rebranded phone, it doesn't work with his Navman bluetooth :S
Postby Hammer » Sat Apr 10, 2010 11:32 pm
TieNN89 wrote:I've seen that Uniden unit
Do you have to switch these units on and off every time you leave the car?...
They do power down when not connected to a unit for more than 10mins. But it's a simple single button push when you hop in the car and it will automatically pair each time (after the initial pairing is done).
TieNN89
Postby TieNN89 » Sun Apr 11, 2010 12:09 am
hmmm was just thinking I'd have a bit of trouble with these units if I was to get one unless I remember to switch it off everytime
Seeing as the car gets parked in the garage and my phone usually stays in the room next to the garage I'd probably stay connected to the unit all the time
de Bounce
Postby de Bounce » Sun Apr 11, 2010 9:42 am
TieNN89 wrote:hmmm was just thinking I'd have a bit of trouble with these units if I was to get one unless I remember to switch it off everytime
That could be a problem with the Blu Ant ST3 as it has a good 10 metre range.
If you move out of range it disconnects, then reconnects when back in range (takes about two minute).
It does not switch itself off when not connected but has a 800 hour stand by time.
If it is connected and you hear it ring, you should be able to redirect the call to the handset.
Motorkhana Video
