Aftermaket gauges?
mitch_f1
Aftermaket gauges?
Postby mitch_f1 » Thu Mar 18, 2010 8:23 am
Where have you mounted them, and how have you bought the wiring into the cabin? Have you drilled hole in firewall, or used existing holes?
Aftermaket gauges?
Postby Lokiel » Thu Mar 18, 2010 10:11 am
Autometer Boost Gauge mounted in single pod on the A-Pillar (I didn't want to use an air vent since I need al the A/C I can get here in QLD).
Vacuum hose is threaded through existing hole in the firewall (this hole is getting very tight now since I also have my Gizzmo MS-2 EBC's solenoid wires going through that same hole).
Here's a "not very good" picture:
The pod is the pod I used:
http://www.modyourcar.com.au/universal- ... auge%20pod
I had to cut it down a LOT to make it fit and add rubber edging to the front to mask the gap between the gauge pod and the A-Pillar. To secure it I used pot rivets. I left enough of the original pod for 3 pot rivets on the bottom edge and 2 pot rivets on the "face edge". I was going to paint the rivets black but like the natural industrial look it gives.
GS
Aftermaket gauges?
Postby GS » Thu Mar 18, 2010 10:27 am
I assume you're talking NA/NB? If so there are a few alternatives including:
* remove one of the eyeball vents and mount a gauge in there
* if you have a single DIN radio, buy or make a panel to fit in the space below. You can fit 2/3 gauges there depending on the size of the gauge
* buy a cover for the A pillar that contains mounts for 1 or 2 gauges.
The position in the vent brings the gauge closer to your eyeline, but obviously if you use your a/c or heater you lose a 1/4 of your outlets. From memory i think a 60mm gauge is the exact size, or you can remove the outer ring from the vent and drop a smaller gauge in there (or at least you can on the NA).
The position under the radio looks subtle and clean, but its a little way from your eyeline. You might need to google to find the suppliers, but ive seen quite a few variations - 2 gauge, 3 gauge, 1 gauge + a pocket, 1 gauge + a clock etc.
The A pillar mounts - the plus is that its level with your eyeline, but i dont like the idea of them blocking my field of vision, and it just has a faint wisp of 'ricer' (probably seen one too many Excels with 'boost' gauges on the a pillar!!).
Personally ive got an AEM WB in a vent (not sure what size it is, but i needed to use the outer ring of the eyeball vent), and 2 60mm gauges in custom panel below the radio.
No need to drill any extra holes in the firewall. You can usually slide the extra sensor wires required for the gauges through the existing grommets, then tap into one of the existing wires behind the dash for a power source.
1989 NA6
RG.net
Aftermaket gauges?
Postby RG.net » Thu Mar 18, 2010 11:45 am
I have two mounted in the centre AC vents, and three mounted above the radio.
I should have sone pictures on my blog somewhere.
Wiring can go through the rubber grommets in the engine bay, with a little bit of force.
TieNN89
Aftermaket gauges?
Postby TieNN89 » Fri Mar 19, 2010 1:23 am
GS wrote:* if you have a single DIN radio, buy or make a panel to fit in the space below. You can fit 2/3 gauges there depending on the size of the gauge
And if we are talking about NB then grab this off me
viewtopic.php?f=44&t=41080
mitch_f1
Aftermaket gauges?
Postby mitch_f1 » Thu Mar 25, 2010 11:27 pm
its for NA
Are NA and NB different?
TieNN89
Aftermaket gauges?
Postby TieNN89 » Sat Apr 17, 2010 11:07 am
mitch_f1 wrote:its for NA
for the Din holder I had for sale then yes they are different
blue_na
Aftermaket gauges?
Postby blue_na » Sat May 01, 2010 10:19 am
How do you remove the outer ring from the eyeball on NA's?
I've removed the eyeball assembly from the tombstone but can't figure out how to separate it.
The emotion of motion... Zoom-Zoom!
broady
Aftermaket gauges?
Postby broady » Sat May 01, 2010 1:17 pm
blue_na wrote:How do you remove the outer ring from the eyeball on NA's?
You don't. It's all one piece.
人馬一体 NA8
6/5/2010
blue_na
Aftermaket gauges?
Postby blue_na » Sun May 02, 2010 6:43 pm
Separated it with screwdriver last night, now have 52mm gauge fitted tightly in the centre of the ring. :D
evil_weevil
Aftermaket gauges?
Postby evil_weevil » Tue May 11, 2010 3:04 pm
hey guys,
the 52mm ones, what brand did you get? easy fit in the NA air vents?
viewtopic.php?f=73&t=62834
Aftermaket gauges?
Postby Lokiel » Tue May 11, 2010 4:12 pm
Autometer mechanical gauge (there are a lot of re-branded Autometer gauges available).
I know that Autobarn sells them (Supercheap sell Cobalt gauges - not sure who manufactres these)
