Radio with Amnesia
Posted: Thu Feb 25, 2010 1:06 pm
by sliq
Hello folks,
Sometimes when i switch off my car, and then switch it back on, my car radio forgets the radio stations i store in it.
Is this a battery problem? Or have I not wired up the audio correctly?
Also, as an aside (not audio related), the motor for my pax electric window squeals whenever i raise/lower the window. It basically sounds like the gears that turn need a good greasing up. I have tried to take out the motor to have a look at the gears but the pax window and one of the beams supporting the quarter window is interfering with its removal. Has anyone had this problem? (And a fix for it)?
Thanking you in advance.
sliq.
Radio with Amnesia
Posted: Thu Feb 25, 2010 1:14 pm
by Locutus
sliq wrote:Sometimes when i switch off my car, and then switch it back on, my car radio forgets the radio stations i store in it.
not wired correctly or poor connection. there is a constant +12V wire which needs to be connected separate to ACC switched power.
battery problem would be obvious - car won't start.
Radio with Amnesia
Posted: Thu Feb 25, 2010 2:03 pm
by sliq
Locutus wrote:not wired correctly or poor connection. there is a constant +12V wire which needs to be connected separate to ACC switched power.
electricity is a foreign language to me
i'll look into it
Radio with Amnesia
Posted: Fri Feb 26, 2010 1:03 am
by silvermiata
Hey Sliq
it should be easy to fix i will have a look at it for you when we meet up
Radio with Amnesia
Posted: Fri Feb 26, 2010 10:52 am
by Juffa
As already mentioned the memory is retained by a constant 12v feed. A bad connection can cause loss of radio memory, or you may have chosen a 12v feed that is switched, or the fuse on the constant 12v feed has blown. Should be easy to track down.
As for the window....the guide channels for the glass could be dry. Get yourself some silicon grease in either a spray or a tube and lube the channels. I prefer the spray as I can reach more places with minimal (if any) need to dismantle the doors.
J.
Radio with Amnesia
Posted: Fri Feb 26, 2010 11:00 am
by sliq
Juffa wrote:As for the window....the guide channels for the glass could be dry. Get yourself some silicon grease in either a spray or a tube and lube the channels. I prefer the spray as I can reach more places with minimal (if any) need to dismantle the doors.
J.
yup, checked that, and it's definitely coming from the motor. i tried spraying the guide channels with white lithium grease but that hasn't resolved the squealing
Radio with Amnesia
Posted: Sat Feb 27, 2010 11:44 am
by Wuey
The constant +12V wire on the head unit is typically a solid yellow wire. Just use a test light or a multimeter to locate a constant 12V source, like the positive feed of the interior lights. I use silicone spray on my window guides too.
Radio with Amnesia
Posted: Sun Feb 28, 2010 3:07 pm
by ll_spud
Easy solution.
You connected the contant and the acc cables the wrong way around.
Constant is the 12V connector usually yellow, and its the memory of the car.
The acc turns the car head unit on, when you got the car in ignition.
The reason why its not saving, is because you got the cables the wrong way around, and its not saving the memory.
Its either that,or your fuse is gone. Check the fuse for car audio.
Cheers.
Radio with Amnesia
Posted: Mon Mar 01, 2010 3:22 pm
by Old Dude
I had the same problem with my car when I wasn't driving it very often. Even though the car would start the battery wasn't at its best, since charging it, I no longer have the problem.
Just a thought
Dale
Radio with Amnesia
Posted: Sun Mar 14, 2010 11:13 pm
by TieNN89
Is this a factory headunit or an aftermarket one?
Did you replace the headunit or remove it or do anything to it ever since it started
Old Dude could be on the dot there if you don't drive it often and your battery gets low
