iphone + mx5
Posted: Fri Jan 22, 2010 11:19 pm
by zorak
I have been searching for a decent way of putting my iphone in my car that 1) didnt involve a plastic windscreen mount 2) sent the audio out via the 30 pin connector at the bottom of the phone as opposed to the audio jack 3) charged the iphone 4)looks nice in the mx5 dash. After realising nobody makes such a thing I decided to make my own...
I used an ebay iphone dock (because the apple version only comes in white), iphone cigarette lighter charger, aux cable, bit of double sided tape and black plastic trim. I hard wired the charger behind the cigarette socket so I still have a working cigarette lighter. It works brilliantly - now I can run rev light watch my g forces driving to work while I listen to music
iphone + mx5
Posted: Fri Jan 22, 2010 11:54 pm
by Bauer
good effort
so does the 30 pin connector go to the head unit and the lighter?
iphone + mx5
Posted: Sat Jan 23, 2010 7:10 am
by zorak
the 30 pin connector goes to the lighter only. There is also an audio jack on the dock which goes to the headunit.
iphone + mx5
Posted: Sat Jan 23, 2010 10:25 am
by bruce
What application are you running (it does rev light and g forces?)
iphone + mx5
Posted: Sat Jan 23, 2010 11:45 am
by MX5CHIC
That is brilliant and very OEM in appearance, can you post a link to the hardware that you stripped in order to make it?
Perhaps a how to?
iphone + mx5
Posted: Sat Jan 23, 2010 12:42 pm
by wazman
This is sweet as.
You should do a how to and throw it up in the tech section
iphone + mx5
Posted: Sat Jan 23, 2010 12:49 pm
by zorak
The app is called rev lite - it shows realtime g force and combines gps and google maps to do lap timing. The full version looks awesome but you need OBD-II to get all the engine diagnostics.
mx5chic - no stripping was required - just plug the usb charger into the cigarette lighter socket ( I wired it in behind the existing one to hide the plug and also so I could keep the existing socket on the dash). Then plug the other end of the charger cable into the dock as well as the 3.5mm jack from the aux input on the back of the stereo (most aftermarket units have them). I pulled out the little cubby infront of the gear stick and mounted the dock in there, covered the surrounding area with some black plastic trim and that was it!
iphone + mx5
Posted: Sat Jan 23, 2010 1:26 pm
by Okibi
http://www.mapmyfitness.com/shop/ibikemount-iphone-bike.htmlThis doesn't look secure enough to work on a bike but you could adapt it to mount the iphone horizontally under your stereo so you could still acess the aircon cotrols.
iphone + mx5
Posted: Sat Jan 23, 2010 1:32 pm
by MX5CHIC
Great, what brand is the charger base? - Belkin ? I have been using a unit with built in charger etc but it is mounted on a stalk which plugs into the cigarette lighter - great system but when the G-Force from cornering kicks in it just topples over
Time to get the soldering iron out and get creative
iphone + mx5
Posted: Sat Jan 23, 2010 1:40 pm
by zorak
the dock is a 4 dollar ebay job - free shipping! dunno how they can do them that cheap.
iphone + mx5
Posted: Sat Jan 23, 2010 6:12 pm
by TieNN89
Although not cheap this is another idea
http://www.holdmyphone.com.au
iphone + mx5
Posted: Sat Feb 13, 2010 12:46 pm
by Ajay
NA Iphone Kit (no modifcation to trim) however it is slightly bulky...
There is also versions for the side of the NB Console without damaging trim as well..
Re: iphone + mx5
Posted: Wed Oct 20, 2010 2:54 pm
by bootz
OBDII socket maybe can provide the power removing the need for muckn with the lighter wires. Plus we get real time computer + engine fault codes. Quick someone tell me the killer app software and I will invest in an I-phone.
I knew there was a good reason for buying a 2002.
