2 Qstn's regarding DVD headunit & engine fans
Smithy
Postby Smithy » Fri Jan 15, 2010 2:34 pm
1) Had a DVD head unit and seperate screen in my NA when purchased, installed now into my corolla... after a few months of daily use the DVD head unit seems to
not be able to load up CD/DVDs. They get taken in and it trus to read them for 3-4 minutes before providing a no disc message... :shock:
ideas ? dirty lens ? cleanable ? its just a no name brand head unit by the way....
2) I was wanting to install a switch on centre console to enable on/off of the A/C relayed fan. Without the use of the A/C itself, so as to get more air sucking through. I've found a few suggestions as to simply tapping into the power for it etc but other suggestions said a seperate relay is needed , though if simple extra wire installed to bypass it would still run off the A/C relay. right ? lol.. suggestions !?
thank sfor help in advance ! :wink:
old rides:
56 Morris Minor Pickup -58 Morris Minor Sedan -86Honda CityTURBO II
95 Mitsubishi RVR Sports Gear -03ToyotaCorollaLEVIN
Juffa
Postby Juffa » Fri Jan 15, 2010 9:25 pm
Can't really help with the DVD player.
On the fan question. I used the following instructions to run both fans in parallel, i.e. both fans are on with or without air conditioning running. I did not add or remove, or anyway modify a relay to do this.
http://www.miata.net/garage/parallel_fan.html
J
Users browsing this forum: No registered users and 34 guests
