few q's in regards to replacing dash + pics
rxmx
Postby rxmx » Fri Jan 08, 2010 7:21 pm
Heya,
Im in the process of replacing my dash as mine had a crack in it. I have the new dash now but the wiring loom behind dash is slightly different in 2 sections. Firstly on the new dash the white plug that plugs into the instrument cluster has less wires and is missing another little plug that mine has for the instrument cluster (see below). Now will this cause any probs if i install withough the little plug? 2nd is where the plugs are for the steering column mine has another extra plug where as the new dash doesnt (see below). Now if i install without these 2 missing plugs will i have dramas, should I just swap the wiring loom and be done with it?
Thanks,
This is my dash old dash with instrument cluster next to it with extra plug.
New dash..
Old dash with extra plug where steering column is
new dash
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Postby Hammer » Sat Jan 09, 2010 8:04 pm
NA or NB?
rxmx
Postby rxmx » Sat Jan 09, 2010 11:40 pm
Sorry forgot to mention, Its an NA...
Postby Jeo » Sat Jan 09, 2010 11:47 pm
Late NA6 wasn't it?
rxmx
Postby rxmx » Sun Jan 10, 2010 12:25 pm
Hi Joe, thats correct - 08/92
Russellb
RIP Nov 2014
Postby Russellb » Sun Jan 10, 2010 5:12 pm
Your best bet is to use the dash loom out of the original dash
That way every thing that work in the old dash will work in the new dash
Easyer than fault finding later
My ClubmanRebuild
MX5 SE Rally car is HERE :)
rxmx
Postby rxmx » Mon Jan 11, 2010 4:58 pm
Thanks for the replies, as Russellb suggested i changed over the loom. Was much easier than I thought
