power windows
WASP
power windows
Postby WASP » Sat Oct 31, 2009 12:46 pm
Hi I suggest you take the switch apart,quite easy,and clean the terminals with a fine emery paper and WD40.What you describe is a common problem.
WASP
ps Why not add your Suburb or City in profile
power windows
Postby Okibi » Sat Oct 31, 2009 1:26 pm
Also you should get inside the door and lube the sliders, rubbers and cable etc, replacing those is a PITA much easier to try and maintain them so they don't snap.
Wuey
power windows
Postby Wuey » Mon Nov 02, 2009 10:15 am
WD40 is only a very temporary measure. It will eventually gum up and stuff the connectivity. Electrical contact cleaner available from your local electronic store works better.
Image 2004 SE
