NC seat belt warning beep
aza5c
Postby aza5c » Wed Oct 28, 2009 9:42 am
I've found threads referring to NA and NB owners unplugging wires and plugs to stop the incessant warning beeps and chimes in their cars, does anyone know how to turn off/stop the seat belt warning beep in an NC? It only activates over about 10-15 klm/hr and as I carry stuff on the passenger seat that weighs more than 5kgs (which seems to be the threshold) the beep goes off and it drives me up the wall! I'm concerned that unplugging wires or plugs etc may affect the seat bolster airbag functionality.
Any help will be appreciated.
***edit : any other suggestions apart from 'doing up the seatbelt' will be appreciated!
Richee
Postby Richee » Wed Oct 28, 2009 10:35 am
One solution is to do up the seatbelt
Mazda Tribute - its a boat
Steampunk
Postby Steampunk » Wed Oct 28, 2009 11:50 am
buy a suitable clip/male part of the belt from wreckers and put that on?
aza5c
Postby aza5c » Wed Oct 28, 2009 12:13 pm
1red5 wrote:buy a suitable clip/male part of the belt from wreckers and put that on?
thats not a bad idea at all, thanks red! :D
AJ
Postby AJ » Wed Oct 28, 2009 4:40 pm
why do you NOT want to wear your seatbelt?
XMX5 Rogues
Alex
Postby Alex » Wed Oct 28, 2009 5:19 pm
AJ wrote:why do you NOT want to wear your seatbelt?
He is wearing his but since there is weight on the passenger seat the beeping goes off as the car thinks there is a passenger without a seatbelt on. It's been mentioned before on this forum, IIRC then one milk container in the passenger seat is enough to set it off.
Also if the sensor is anything like the NB then it's not so much the clipping that stops the beeping, it stops after a certain amount of seat belt has been given out from the reel, it doesn't need to be clipped.
In the NB you can stop it by undoing a plug under the steering column, unsure of how to do it in an NC though.
AJ
Postby AJ » Wed Oct 28, 2009 5:38 pm
aah, well, in the NC, as long as the belt is clipped in, the alarm will stop. :)
XMX5 Rogues
Users browsing this forum: No registered users and 221 guests
