2004 SE Wiring HELP
blackster
2004 SE Wiring HELP
Postby blackster » Fri Sep 04, 2009 1:43 pm
Boris, you do not have intercept the 02 sensor line directly behind the ECU, if you are trying to hook the up the 02 clamp.
Intercept the 02 sensor line directly behind the rocker cover in the engine bay. You cant miss it, it is the only front 02 sensor plug we have. We do not have a rear 02 sensor going to the CAT.
Run the wire along with the pressure signal through the firewall and leave the 02 clamp in the passenger footwell.
Added bonus you dont have remove the ridicilous security bolts to get to the ECU. Unless you plan on doing an ECU upgrade.
You will be hard pressed finding anyone providing with you AU SE ECU pinout diagram, unless you purchase aftermarket ECU/harness locally.
PS. Posting the same question twice in different threads wont create more exposure.
Previous
04' MX5 SE.
02' MX5 Classic ed.
MINX
2004 SE Wiring HELP
Postby MINX » Fri Sep 04, 2009 2:03 pm
+1
Splice it in engine bay.
I mounted my clamp just under dash/centre console on drivers side so i can hear it work when roof is up.
2004 SE Wiring HELP
Postby bruce » Sat Sep 05, 2009 10:32 am
A major OT, but Boris, did you take your Aussie SE to the UK? Do they sell SEs in the UK?
