Volt Gauge
Robbo
Vehicle: 10AE
Volt Gauge
Postby Robbo » Tue Aug 18, 2009 5:02 pm
I am about to install a volt gauge in my NB. I hope someone can assist with directions as to the best way/easiest way and where to wire it up to. I know the wires will have to be joined into the wiring system somewhere "BUT WHERE!" :roll: :idea:
Hope someone can help.
Volt Gauge
Postby Jeo » Tue Aug 18, 2009 5:06 pm
Any 12v supply right?
Cigarette lighter is fairly accessible.
AJ
Volt Gauge
Postby AJ » Tue Aug 18, 2009 5:15 pm
straight to the battery if you want an accurate reflection of the amount of voltage in your electrical system.
XMX5 Rogues
Robbo
Vehicle: 10AE
Volt Gauge
Postby Robbo » Tue Aug 18, 2009 5:27 pm
Thanks for the info Jeo and AJ. The c/lighter may be the closest option as it is a long way to the battery and a bit of stuffing around to get the wires there.
RawSouth
Volt Gauge
Postby RawSouth » Wed Aug 19, 2009 11:59 am
Which brand of guage are you planning to use? and where are you thinking about putting it mate?
Ive been thinking about doing this too
ロードスター
Robbo
Vehicle: 10AE
Volt Gauge
Postby Robbo » Wed Aug 19, 2009 12:36 pm
Hi there RawSouth I am thinking of either a Stewart Warner or a VDO gauge. I am also planning on a oil temp and a vacuum gauges. The holder I can get from Mazda parts in the UK for about $40 delivered and it fits the DIN space under the radio. You can get either a 3 gauge one or a 2 gauge holder.
Robbo
Vehicle: 10AE
Volt Gauge
Postby Robbo » Wed Aug 19, 2009 12:43 pm
Check out www.mx5parts.co.uk for the gauge panel plus other good bits
RawSouth
Volt Gauge
Postby RawSouth » Wed Aug 19, 2009 2:38 pm
Robbo wrote:Hi there RawSouth I am thinking of either a Stewart Warner or a VDO gauge. I am also planning on a oil temp and a vacuum gauges. The holder I can get from Mazda parts in the UK for about $40 delivered and it fits the DIN space under the radio. You can get either a 3 gauge one or a 2 gauge holder.
Hey robbo, does this holder fit underneath the OEM standard radio?
The space underneath it doesnt seem big enough, but im happy to be corrected :)
Id like to put in Volts, oil temp and proper coolant temp guages.
ロードスター
Robbo
Vehicle: 10AE
Volt Gauge
Postby Robbo » Thu Aug 20, 2009 11:50 am
Hi Raw South, I have a 10ae and it appears from what info I have obtained this gauge mount that I can get from the UK replaces the box (DIN) space under the standard radio.
GP
Volt Gauge
Postby GP » Thu Aug 20, 2009 2:07 pm
Needs to be connected to the battery so you get a true reading. Cig lighter will be going thru a fuse and everything.
Graham
RawSouth
Volt Gauge
Postby RawSouth » Thu Aug 20, 2009 2:19 pm
Is it possible to fit gauges in here?
Josh
ロードスター
Volt Gauge
Postby Jeo » Thu Aug 20, 2009 2:48 pm
I'm sure its possible, but as to whether a total novice could get them in there cleanly, I'd say not.
Robbo
Vehicle: 10AE
Volt Gauge
Postby Robbo » Thu Aug 20, 2009 3:30 pm
Hmmm. It appears your console setup is different to mine. Mine will be easy but yours may need a professional approach. All I have is the radio then cubby hole box then the heater etc controls.
Robbo
Vehicle: 10AE
Volt Gauge
Postby Robbo » Thu Aug 20, 2009 3:45 pm
This is the gauge holder
Volt Gauge
Postby Lokiel » Fri Aug 21, 2009 7:10 pm
The holder you've indicated is for a standard Single-DIN slot (eg. most head units conform to the single-DIN standard and simply slide into this slot; some use a Double-DIN slot like your OEM head unit and many DVD/GPS head units). This holder will NOT simply fit where you've indicated since that slot is a custom slot for the MX-5 (possibly other Mazdas too), it's NOT a Single-DIN slot. Looks like you'll need to manufacture your own holder to fill that slot.
