Anyone installed new speakers on a factory NB8B headunit?
matt9111
Postby matt9111 » Thu Aug 13, 2009 8:11 pm
G'day guys,
Just wondering if anyone has fitted aftermarket speakers to there NB8B's without changing the headunit?
Because the NB8B already has a factory amplifier? Correct me if I'm wrong, lol
If anyone has, how did the new speakers sound?
Great looking 02 BLACK NB8B, Tein S Tech Coils, Whiteline Adjustable Sways F&R, Carbing Alloy Rear Strut Brace ;)
Postby sliq » Thu Aug 13, 2009 10:51 pm
the factory head unit is crap.
you won't gain much from just upgrading speakers because there still won't be produce enough power to make the most of its potential.
i had my amp installed last night; speakers were clearer and louder at a lower volume than before...
bigdog
King of the kennel
Postby bigdog » Thu Aug 13, 2009 11:36 pm
I put a set of VDO 8 inch 3 ways (They only cost me $20 :D ) in my doors on the std head unit and wiring - definite improvement over stock and with a decent crossover I think they would be great... just haven't got around to it yet, lots more important things to do. :D
philz
Wheel guru
Postby philz » Fri Aug 14, 2009 1:54 am
matt9111 wrote:G'day guys,
Of course it has an amplifier, if there wasn't one, you would not be able to hear any music, but it's tiny which fits in the headunit and does not have enough power, compare it with external amplifer which are 30cm in length and have massive heatsinks, and you can understand the amount of power.
Aftermarket units might have slightly more power, but it is not enough for you to tell a difference and you can't back to back, because the aftermarket speakers will be different.
Most aftermarket speakers will have a higher sensitivity compared to normal speakers. so you will perceive that there is more power, but in reality it's just more sensitive and so at lower volumes it will be louder.
But other things come into play as well, such as larger surface area, ie/ 8" woofers.
Upgrading speakers are good if you want to retain the original headunit.
matt9111
Postby matt9111 » Fri Aug 14, 2009 9:32 pm
I thought the NB8B's had a separate amplifier to the head-unit itself?
Hmm.... maybe I'll just wait for this digital radio thing to take off and then I'll get a decent digital radio head unit.
edit: Lol, I know what amplifiers are, I used to have doof doof in my first car that cost around $1000 could rival most $3000 systems....House hifi speakers amped = win! Lol
Matty
Garry
Postby Garry » Fri Aug 14, 2009 9:59 pm
The Bose branded head units have a seperate amp but I dont think any Bose systems were fitted to Aus delivered NB8B's.
Postby Okibi » Fri Aug 14, 2009 10:21 pm
I put the pioneer 8" round 3 ways in with the factory NB8A head unit, there was an improvement.
philz
Wheel guru
Postby philz » Sat Aug 15, 2009 12:09 am
Fli audio make an 8" component set for under $200, not a bad price.
matt9111
Postby matt9111 » Sat Aug 15, 2009 9:48 am
Cheers for your help :), I might go down to glitterbarn today and check a few speakers out.
I can always just buy speakers now and then a new headunit later on,
