ECU in SP - Which models are the same
RobH
Postby RobH » Thu May 14, 2009 3:08 pm
I need to confirm if the ECU in the 2002 SP is the same as in older MX5s? I know that it will have a different program in it but is it the same hardware? Is it going to be the same as an NB8A or even an NA8?
I need to get my hands on an ECU to make a wire in ECU into a plug n play by cannibalising the plug from a stock one and I don't want to destroy my stock one to do it.
If anyone has knowledge in regards to this it will be greatly appreciated.
Silver SP - KAAZ LSD, Enkei Rims, PSS9's and Project Mu Caliper upgrade kit.
Fatty
Postby Fatty » Thu May 14, 2009 3:13 pm
you don't neet to cannabilise a stock ecu just to get the plug. the plugs can be bought seperately.. there is a guy on ebay that sells them. i got a brand new one for my na6 for about $20 from him. i might be able to find his details if you want. i think thats a far better way to go, start fresh rather than try to use a chopped up old plug.
of course this doesn't solve your immediate problem coz you still don't know what sort of plug you need, but the info is out there and hopefully someone else can help.
RobH
Postby RobH » Thu May 14, 2009 3:15 pm
Details on where to get the plug would be great thanks Fatty.
mx52nv
Purple Porsche Eater
Postby mx52nv » Thu May 14, 2009 3:18 pm
Get a factory harness extension from Boomslang in the U.S. :mrgreen:
If there is enough EOI in this, I can organise a group buy! :wink:
Les @ MX5 Shop
P.S. that is what I did with any customer's MX5 running different ECUs.
Fatty
Postby Fatty » Thu May 14, 2009 3:22 pm
http://stores.shop.ebay.com.au/efi-online__W0QQ_armrsZ1
try that. hopefully he might be able to sort you out.
Fatty
Postby Fatty » Thu May 14, 2009 3:23 pm
ah yes the boomslang is also a very good option.
Benny
Postby Benny » Thu May 14, 2009 5:40 pm
To try and answer the original question, yes, the ECU in the SP is the same as other NB8B's.
The main chip has been re-programmed by Chip Torque in Qld, but the box and all the plugs are the same.
Russellb
RIP Nov 2014
Postby Russellb » Fri May 15, 2009 7:36 am
My ClubmanRebuild
MX5 SE Rally car is HERE :)
RobH
Postby RobH » Fri May 15, 2009 9:29 am
Thanks for all the great info. This is going to be very helpful.
devolutio
Postby devolutio » Thu Jun 11, 2009 11:45 am
Russellb wrote:Try Tf Elecronics in QLD
http://www.tfelectronics.com.au/PageFiles/connectors.html
"The connector is $35 + GST. Add $15 for overnight shipping (TNT)"
http://wolfems.cart.net.au/details/2256528.html
AEM do it for $65
Haven't gotten a reply from the ebay store as yet. Did you find any more leads RobH?
devolutio
Postby devolutio » Thu Jun 11, 2009 12:51 pm
http://tuner-deals.com/index.php?main_p ... 0fa515ae17
just found these. works out to about $70 to get one board with the connector, posted to australia.
anyone interested in getting one as well? would be about $55 (each) to get 2. would probably one be worth it if you are in melbourne.
RobH
Postby RobH » Tue Jun 16, 2009 1:57 pm
Hi Devolutio,
It turns out that the company in Cairns (TF Electronics) is the same company that made the ECU I am installing into the car (ViPec). I am going to send them a picture of the plug out of my ECU and he is hopefully going to be able to match or make a connecter for me that will plug straight into the ViPec.
I will hopefully have this finalised sometime next week. Luckily I am not in a hurry because the ecu is not going into the car until late August.
Let me know how you go with your option.
RobH
Postby bruce » Tue Jun 16, 2009 2:56 pm
I'm in Cairns. Need any help, just ask me.
Postby 93_Clubman » Sun Jun 21, 2009 1:51 pm
devolutio wrote:http://tuner-deals.com/index.php?main_page=shopping_cart&zenid=31909226411f211e1280e60fa515ae17
there's now a closeout sale on those breakout boards & connectors, so v1 is US$8 & v2 starts at US$12
RobH
Postby RobH » Tue Aug 04, 2009 4:23 pm
After a couple of e-mail discussions and some photo's we have now found that the MX5 connection to the ECU is the same as a Supra (Toyota Supra 2JZ-GTE VVT-i) less two end sockets. TF Electronics have these connectors in stock and have removed two sockets and are sending the modified connector to me today. Hopefully once this is wired to the wiring loom that came with the ViPec ECU it will then act as a plug and play straight into the Mazda and will only need tuning before we are up and running.
All things working out OK we will then be making aprox 180 - 200 rwkw which is more than enough to get into trouble :twisted:
Users browsing this forum: No registered users and 139 guests
