Battery Kill Switch
Pamex
Battery Kill Switch
Postby Pamex » Tue Apr 21, 2009 7:21 pm
Hi all,
Partly to have something reasonably easy to do at the upcoming dodgy day, partly for security reasons and partly so I can replace the aircon switches with something else I'm planning to put a battery kill switch where the existing a/c knobs are.
I'm guessing there'd be a few people on here that have done this.
Looks reasonably straight forward even for a nuffy like me. Any tips and tricks, or recommendations on 'Ooh, I found X handy to have whilst doing mine' at all?
Pam
green_comet
Car Detailing Guru
Battery Kill Switch
Postby green_comet » Wed Apr 22, 2009 4:58 pm
Hey Pam,
I looked into doing this about a year ago, but just never got around to installing one. It seems pretty straight forward to do on the MX5, and I found this step by step info very helpful.
Ryan
Pamex
Battery Kill Switch
Postby Pamex » Wed Apr 22, 2009 5:01 pm
Thanks Ryan! Looks good.
Come along to the dodgy day and install one too. (I should clarify that by saying that everyone needs one of those boys behind their tombstone. Radio? Bah. Have Korean boy, will travel.) :mrgreen:
Does anyone's mex ever stop evolving? When/where is this modification madness going to end?
Stu
Battery Kill Switch
Postby Stu » Wed Apr 22, 2009 6:11 pm
Pamex wrote:Looks reasonably straight forward even for a nuffy like me. Any tips and tricks, or recommendations on 'Ooh, I found X handy to have whilst doing mine' at all?
It can't be any easier than booking tickets at a cinema :mrgreen: :mrgreen: :mrgreen:
Pamex
Battery Kill Switch
Postby Pamex » Wed Apr 22, 2009 6:49 pm
Cheeky bugger. :mrgreen:
wun911
Battery Kill Switch
Postby wun911 » Wed Apr 22, 2009 8:30 pm
you can get lightweight battery that will fit in your giant sized hand bag
every ounce counts
Pamex
Battery Kill Switch
Postby Pamex » Wed Apr 22, 2009 8:58 pm
AAA size? Will that work?
Maybe if I include a mouse on an electic bicycle to aid it under heavy loads. A mouse that bites for the security bit.
Battery Kill Switch
Postby hks_kansei » Thu Apr 23, 2009 11:14 am
most simple solution.
one end on terminal, other connects to cable.
will cost you about $10 or $20 or somethign, and take about 10mins to install.
Tedsmx5
Vehicle: NA8 - Supercharged
Battery Kill Switch
Postby Tedsmx5 » Thu Apr 23, 2009 3:09 pm
That's what I used and it works great :D . I also have one of those AAA's, 1 year old and still going well.
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
wun911
Battery Kill Switch
Postby wun911 » Thu Apr 23, 2009 4:10 pm
Thats not a bad idea I know NB8B can dead lock a boot when you lock the boot with your key.
every ounce counts
Battery Kill Switch
Postby hks_kansei » Thu Apr 23, 2009 4:13 pm
wun911 wrote:Thats not a bad idea I know NB8B can dead lock a boot when you lock the boot with your key.
NB8A can as well.
and it would be simple to do on an NA too, just remove/cut the release cable going to the cabin release, the only problem is you would need to use the key every time.
TieNN89
Battery Kill Switch
Postby TieNN89 » Fri Apr 24, 2009 12:17 am
NB8A can as well.
did you have to do any mods to the lock?
i remember reading somewhere that you had to mod the lock
silvermiata
Battery Kill Switch
Postby silvermiata » Fri Apr 24, 2009 5:48 pm
only problem killing the power all together is your radio stations will never be stored after killing the battery which is pretty annoying..
Battery Kill Switch
Postby sliq » Fri Apr 24, 2009 7:47 pm
silvermiata wrote:only problem killing the power all together is your radio stations will never be stored after killing the battery which is pretty annoying..
good thinking silvermiata 8)
wun911
Battery Kill Switch
Postby wun911 » Fri Apr 24, 2009 8:17 pm
No mods needed... if you lock the boot with the key instead of the remote then turn the key the other way its dead locked so even if your in the car you can press the boot release leaver...
BTW there are 2.5 kg battery covered in CF nice hand bag accessory I want to do GB on them if anyone is interested...
Dont worry about the radio you remove the radio every time you go to track anyway...
every ounce counts
Users browsing this forum: No registered users and 138 guests
